petrolhead611's Avatar
Send a message via AIM to petrolhead611
Pilot bearing
Removed this using a 16mm dowel sanded down to just under 15mm dia and some plasticine. The dowel compresses the plasticine and out pops the bearing. Now, how do I install the new bearing? Does it need leaving in the freezer for a while before pressing it in? Do I have to grease the bearing with ordinary LM grease before installation?
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 07-16-2012, 01:43 AM
That Guy
Techno Duck's Avatar
Freezing the bearing will help, but you gotta do it quick. I lightly lube the bearing race with a light oil, then tap it in place using a socket. make sure the socket is the right size or you can damage the dust seal.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-16-2012, 02:37 AM
ace_944's Avatar
I just used a piece of wood and a little grease to do mine didn't freeze it or anything.
87 944 n/a
Old 07-16-2012, 04:52 PM
+1 ^^ the pilot bearing is probably the easiest and most satisfying part of a 944 clutch job!
Old 07-16-2012, 09:31 PM
