944S valve spring removal ?
Does anyone have a good (inexpensive) source to buy a valve spring compressor tool that will work on a 944S head?
Is there a way to remove the springs and valves without the specialty tool? |
just rent one from o'rielly or autozone. doesnt need a special adapter just lots of patience lol
1983 944 Guards Red (87' Implant Complete) |
What style of compressor did you use?
Check with Baum Tools or Samstag tools. The one from Autozone will not fit down into the area for the springs on a 16 valve head.
Good luck, George Beuselinck |
After I had a hard time finding the right spring compressor for sale, I fabricated my own adapter and fit it onto a large C Clamp. Used padding on the valve head side. Worked like a charm.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
Nothing else will get into those deep lifter pockets
dude |
All you need is something that will fit over the spring without hitting the head around it, not damage the valve/spring, and allow access to the keepers. I cut a section of 1 in square stock with an angle grinder and removed one side so it was 3 straight sides w/two 90 degree angles. Then I compressed the sides with a vise to get it to fit inside the recess in the head. Last, I put it on the bench grinder to even up the sides and get a nice flat surface to put on the spring. It cost $0.50 of metal, 30 minutes of labor, and 2 beers.
Thanks guys!
For anyone who hasn't seen the inside of a 16v head, here is why the commercially available tools won't work... Here is the tool I fabricated for the purpose. 1" PVC is strong enough to handle the load and soft enough not to damage the metal. Total fabrication time was about 5 minutes. Here is what it looks like in place. You can see the windows provide plenty of room for access. I used a large clamp from Lowes (cost $19) to compress the spring. I was originally going to buy an 8 inch c-clamp but when I saw this clamp with the red plastic protective caps I couldn't resist. Here it is in use. You can see one of the wedges has been dislodged and the other is still in place. I found myself looking through the window on one side while inserting the pick through the window on the other side. It worked quite well. |
Gon fix it with me hammer
bump on this thread.. am at the same stage : not one valve compressor that fits the 944S head
gonna try the PVC thing you figured out.. small question.. how did that method work out on re-assembly ?? |
I made the same thing as Pacitto only aluminum
dude |
tried it just an hour ago, worked fine in pvc ..
SLED GUITARIST
I purschased a kit on fleabay. @$25 worked good. Had the tall compressor part. I think it was for porsches, vw, and bmw.
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
