Dash lights and door light switch
Finally got to drive the car around a bit and its nice.....i missed how the 944's drove
anyways, the dash instrument lights dont come on with the headlights on. the rest of the lights do come on. checked the fuses...ok and rolled the dimmer...no luck. I didnt go deeper that that...hopefully today.
also when the doors are closed the interior light stays on...it dims a bit when the doors are closed...otherwise stays on unless i switch the lights off....same in the hatch light too. now i know why the battery died so soon
i should have time either today or this weeked to find out why. Im hoping the gurus could point me in the right direction where to start looking.
thanks
Old 07-20-2012, 05:41 AM
aj951's Avatar
As far as the interior lights staying on, I would start with the door switches located in the door jam. You can try and clean them with some contact cleaner from Radio Shack or just replace them.
AJ
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 07-20-2012, 07:09 AM
Back from Beyond
Early or late car? Check to make sure the door switches' wiring doesn't have a ground fault. They shouldn't be grounded unless the door is open.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-20-2012, 08:58 AM
85.5....with the newer dash....i assume early. i do plan on removing and checking the door switches first thing
Old 07-20-2012, 10:13 AM
The 85.5 with the oval dash is considered the later model 944, but has the EARLY wheel offset. The 87 model 944's came with the LATE wheel offset. Never assume anything.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 07-20-2012, 05:01 PM
ok....so i checked the instrument cluster lights again this evening. they do work. I didnt know they illuminate from the bottom of the dash towards the gauges. i checked them in the early evening last night. they do look dim.....i ASSUME ..... they are supposed to look like that. i thought they illuminated from behind the gauges. i removed the surrounding bezel and the lights do look bright.
the door light switches started to work like they should. I will check the switches tho tomorrow.
Old 07-20-2012, 07:16 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Those lights are dim because the bulbs have silvered and the bottom of the plastic that's supposed to refract the light to the gauges has turned to crap. There's a repair kit for fixing the gauge cluster lighting: Ebay lister: 9xauto. $28 for the kit.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-21-2012, 06:31 PM
