black_falcon's Avatar
Hatch suddenly hard to shut
Suddenly the hatch on my 86 requires a firm slam, otherwise it won't latch. Is this a problem with the two latch pins or the mechanism?
Old 07-24-2012, 02:57 PM
AFM #725
Gawernator's Avatar
Maybe the pins are out of adjustment or you could try getting new hatch seats from only944
Old 07-24-2012, 05:33 PM
968 GUY's Avatar
Lube is good also. Cables and latches.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 07-24-2012, 05:37 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Begin with cleaning and lubing the pins and extend their reach about 1/4". See if that changes it. Also, clean and lube the capture claws inside the receiver.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-26-2012, 12:05 PM
monomoy4's Avatar
What brand/type of lube do you recommend for these latches, etc. I'm having the same issue with the hatch lid.
1987 924S 5 Spd
1979 Jeep CJ7 3 Spd
Old 07-26-2012, 01:34 PM
Toofah King Bad
Rasta Monsta's Avatar
Hood struts are bending the glass hatch frame out of shape. Water leakage is next.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-26-2012, 01:40 PM
968 GUY's Avatar
The cables get gummed up along with the catches. Since the releasing of the latches involves an actual mechanical pull on the cables, the release is less likely to show problems unless they are major.
I made sure my cables were lubed, used PB Blaster or something along that line of lube.
I cleaned the latches and pins and put a medium weight, light colored grease on them (dielectric, because thats what I had). I used light colored because of getting it on hands, clothes, etc.
In my opinion, adjusting should be after lubing did not do as well.
There are 2 adjustment that can be made.
1) adjust pins in or out. Normally as the seal gets older, you should have to adjust the pins in, or shorter. If replacing the seal, usually out, or longer.
2) i'm not sure if I loosened the top or bottom of the latching assy.,but I believe it was the lower part where the pins fit into...any way loosened the nuts slightly and closed the hatch, crawled into hatch area and tightened them.
Obviously easier with 2 people. You may need to do this a couple of times.
In my opinion, the hatch should close with a slight push with a hand on each side of the hatch.
I try to not slam the hatches because of the separation issue, already had to do a fix on the car the PO called a 9 out of 10 and have spent a lot fixing the "little things" he claimed to have paid so much attention to,
Old 07-26-2012, 02:18 PM
968 GUY's Avatar
P.S. I have heard nothing but good things about the seats from only944. Plan to get some for the 951 as it squeaks and lube or adjustment does not help.
Old 07-26-2012, 02:22 PM
