wilkrod's Avatar
Brake Booster Delete?
Hi all,
Just wondering if anyone has ever done a brake vacuum booster delete?
Jeff
Old 08-03-2012, 10:57 AM
flash968's Avatar
not a total delete, but i drove a 968 with the hydroboost system. TOTALLY SUCKED!!!
Old 08-03-2012, 11:03 AM
isn't that what the v8 swap guys do?
Old 08-03-2012, 11:41 AM
flash968's Avatar
lol - yup - this one was installed by somebody who does them all the time too, so i tend to think the installation was not the problem. horrible pedal feel. i was afraid to push the car very hard, as i had zero confidence in the brakes.
Old 08-03-2012, 01:03 PM
You could go with the Wildwood MC (or dual MC?) setup some V8 guys use. Not sure if that's any better though
1988 944 N/A Depowered Rack, 968 Swap "In Progress"
Old 08-03-2012, 02:25 PM
I deleted my booster and all of the stock pedals in favor of a floor mounted pedal box.
I did so to make room for a v engine. But it has also had the effect of moving my seating position rearward which has made me at 5'8" fit in the car much better.
Rich
Old 08-03-2012, 04:03 PM
You can delete it and use a dual MC setup with a balance bar, tandem MC, hydroboost or and electric boosted system.
2010 Cayenne GTS
Old 08-04-2012, 08:20 PM
Why do you want to delete it? If for space you could try a 924 booster which is smaller diameter. The master cylinder off a Mazda Millenia is half the length of the 944 one but has almost the same bore/stroke. It will need an adapter to attach to the booster though.
Old 08-05-2012, 09:27 AM
9FF 9FF is offline
9FF's Avatar
Just an FYI for anyone swapping brake boosters for whatever reason. The pre 88 cars had a 3.0:1 assistance from the booster, the 88+ had a 3.4:1 (more) assistance. Ask me how I found out
Old 08-05-2012, 07:49 PM
What about a remote vacuum booster? I know the late A-H 3000 had these and I'm sure there are others.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 08-06-2012, 12:53 PM
9FF 9FF is offline
9FF's Avatar
A remote booster would work but where would you put it on a street car. On a track car maybe in the passenger footwell. Lot of work though, you have to custom make brake hardlines from the engine bay to wherever you install it. Lots of cars have them, in older Alfas that is all they used.
Old 08-06-2012, 01:11 PM
