Anyone know a 968 genius??
Because I need that person's help. I cannot find the radiator cooling fan resistors for my 1992 968. I've called two local dealerships [spoke to the foreman and 944 specialist at each, they are all stumped], I called Parts Heaven and spoke to their foreman, and I've looked in the 968 manuals and cannot find them anywhere. I've gotta find these things to solve my cooling problem, once found the rest is easy. Just for your info the resistors are not in the passenger footwell like on the 944's [the airbag computer is there instead] and I haven't been able to see for sure if they're on the fan housings but I pulled the airbox and crossmember off unable to find them there. Phone numbers, other contact info, or if you could call them locally I'd appreciate it.
