-   -   Installing a Water/Methanol Injection Kit (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/697127-installing-water-methanol-injection-kit.html)
ideola 08-20-2012 04:42 PM
This week, I installed a Snow Performance Stage 2 Water/Methanol Injection System (part# 20010) on the 941 (for those that don't know, this is a 1980 931 2.0L with a 944 body kit). The previous weekend, I finally was able to correct the faulty wastegate, and installed a dual-port in-cabin boost controller while I was at it. I'll post more details on that install later.
I decided to try out the water/meth approach on the 941 because it will provide an excellent comparison to the top mount intercooler of the 937 and the top mount charge cooler on the Club Sport. Here are photos of the components in their installed locations:
I installed the pump on the front inner fender well. This was easy for me because I had previously relocated the ignition module to the little tray / shelf that sits at the bottom of the fender just behind the LHS headlight. The bracket for the ignition module provides a perfect location to tuck the pump out of the way, with relatively easy routing of the electrical and water lines:
https://lh4.googleusercontent.com/-C...0/IMG_2727.JPG
The kit includes a nice reservoir, but I didn't want to have to deal with making my own brackets or mounting setup. Since the 941 has already been converted to the 944 coolant reservoir, I decided to see if I could use the stock coolant reservoir and bracket instead. All I had to do was make a minor downward bend on the bracket to clear the 944 coolant reservoir.
https://lh4.googleusercontent.com/-n...0/IMG_2728.JPG
https://lh6.googleusercontent.com/-X...0/IMG_2729.JPG
Here is a good shot of the water line port that was provided with the kit (lower right corner of the photo). As a stroke of amazing luck, the threaded insert screwed right into the lower hose barb fitting of the stock coolant tank. It was very snug, and actually cut threads in the plastic. The "goop" provided in the kit, sealed it up nicely. I also used an M6 bolt to plug the upper overflow port:
https://lh6.googleusercontent.com/-S...0/IMG_2730.JPG
I had to purchase a 1/8-27 NPT tap and die. I practiced on a busted up charge tube. This was the scariest part of the install...drilling a hole in my charge tube, and then tapping it for the nozzle. The kit included three nozzles, I used the smallest one, which is rated for 250-325BHP applications. The nozzle needs to go as close to the throttle plate as possible. You can install it after the throttle plate if you also purchase the optional solenoid setup to prevent backflow during off-throttle. I chose to put it before the throttle plate:
https://lh5.googleusercontent.com/-l...0/IMG_2731.JPG
https://lh5.googleusercontent.com/--...0/IMG_2732.JPG
I mounted the control module on the LHS inner fender frame spar, just next to the fuel filter. In the lower left hand corner of this photo, you can see the white Tee in the boost signal line; this line is fed from the S2 port on the back of the manifold used to provide boost input to the DITC; since the 941 is an S1/S2 hybrid with no DITC, I use this port & line to feed my boost gauge. I simply teed into it using the Tee and line provided in the kit. This boost signal line is used to feed MAP to the control module:
https://lh4.googleusercontent.com/-8...0/IMG_2734.JPG
The control module has some small dials on it that let you set where the spray begins and the max output. I set the lower threshold to ~5-6 PSI, and set the upper to the max setting. The control module varies the voltage to the pump based on the boost signal, which in turn provides a linear increase in boost-cooling spray into the charge tube as boost increases.
The kit includes a green LED and a red LED. The green LED is configured to indicate when the pump is activated, and the red LED is configured to indicate when the reservoir is low. I have not yet installed the low-fluid sensor, but I did go ahead and install the LEDs in my A-Pillar gauge pod, right next to the boost gauge. This is an ideal location, as the green LED lights right up as the boost hits the 5-6 psi range on the gauge, and stays on until boost falls below that threshold:
https://lh6.googleusercontent.com/-n...0/IMG_2726.JPG
https://lh5.googleusercontent.com/-s...0/IMG_2724.JPG
https://lh6.googleusercontent.com/-1...0/IMG_2723.JPG
The wiring was pretty simple, just need to find a source for keyed-ignition to tap into. The instructions were clear and easy to follow, including the mechanical test routine and the electrical test routine to make sure the components are all working properly before driving the car. I was very impressed with the kit, as it included everything required for the install except for a mounting bracket for the reservoir, and the NPT tap & die.
ideola 08-20-2012 04:43 PM
After I got everything installed and tested, I took the car out for some test runs. I really like the in-cabin boost controller setup I have...it's the same one that I configured in the Club Sport. Looks like this installed:
https://lh4.googleusercontent.com/-g...0/IMG_1919.JPG
This regulator has very large ports. I am using 1/8" hose barbs with 1/8-27 NPT 90-degree threaded fittings to provide mounting points for the boost signal line. The signal line is standard off-the-shelf 1/4" fuel line, and I'm using spring-style hose clamps to keep the lines on the hose barbs. This regulator does not exhibit any boost spikes whatsoever, as is commonly reported with other off-the-shelf boost controllers, which have small port sizes and can't contend with the relatively massive chamber of our 930-derived wastegate. Not a problem for this setup!
As you can see from the photo, I mounted the boost controller by modifying the ashtray. To change boost settings, it is quite easy to snap the little knob up, and then give it a twist. I was very happy with the "granularity" of the regulator, as I was concerned that tiny turns would result in big changes. Not so.
My wastegate currently has the stock US-spec 6 psi spring. With the knob turned all the way counter clockwise, I have stock US-spec 6 psi of boost. A 180 degree turn takes me up to 10 psi. Another quarter turn from there, I have ~12 psi, and another quarter turn or so puts me at ~15 psi. So the granularity is nice and very intuitive.
To plumb the boost controller, I put a brass tee into the port where the boost cutoff switch is located. The boost cutoff switch goes in one port, and another 1/8 NPT barbed hose fitting goes in the other. I connected the "feed" or "inlet" line to this fitting, ran under the charge tube and into the cockpit, down under the console and over to the ash tray, where it is connected to the inlet of the regulator. Another line is connected to the outlet of the regulator, run back under the console, through the firewall, and then down behind and under the coil to where the wastegate sits. I used a barbed banjo fitting with an M10 (I think) banjo bolt to connect the outlet from the regulator to the top port of the wastegate (after unscrewing the stock "mushroom" vent valve, of course).
Routing the boost actuator in this fashion provides pressure to the top of the wastegate, keeping the valve firmly closed until the specified pressure is exceeded. This gives you full benefit of ALL of the boost with no wastegate creep, until the desired pressure is reached and the valve cracks open.
I have only just begun experimenting with the boost controller and the meth injection. I am currently running straight windshield solvent, and have not yet experimented with the "boost juice" provided with the Snow Performance kit. In any event, on a typical Michigan summer evening run, with ambient temps below 80F, I could run about 10 psi with no worries about pinging. about 12 psi, and under some conditions, I could here some very slight pinging.
With the meth injection kit, there is no pinging whatsoever at 12, and I took it as far as 15psi, and couldn't hear any pinging. I am reluctant to push too hard too fast, as I don't want to blow up this motor, but I am confident that 15 psi with the meth injection going should be no problem.
And let me just say, the difference between 6 psi, 10 psi, 12 psi, and 15psi is palpable. So far, even though I am very early in my experimentation, I am extremely pleased with this setup...and I suspect the 941 can easily hang with the 937...maybe even outpace it.
I am just starting to think about a knock detector, and still have hopes of getting to a dyno for better tuning, but that will be down the road. In the meantime, for the money and ease of installation, I don't understand why more of us aren't just getting a boost controller and meth injection kit. Intercoolers are nice, for sure, but this setup was less than $600 all in, and took the better part of a day to install...which is way cheaper, less trouble, and less expense than installing an intercooler.
Gawernator 08-20-2012 08:37 PM
Woah.
