1.2gees's Avatar
Send a message via AIM to 1.2gees
Waterpump bolts stuck?
I'm having trouble removing my water pump bolts, I don't want to break them in the block what should I do?
Thanks for any advice.
Ahmet
Cheers!
Old 05-27-2002, 04:37 PM
951carter's Avatar
make sure you tap them to wake them up. quick jerks seem to work better than steady pressure, but make sure to hold the wrench straight. an air wrench works good on these usually
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 05-27-2002, 08:33 PM
Petie3rd
Mrmerlin's Avatar
Hi this may be too late but I would try hitting the head of the bolt with a hammer (dont hit hard enough to distort the bolt)
Did I mention to use some PB Blaster before hitting the bolt then get a good socket on it and first tighten the bolt only very slightly, your not trying to break the bolt only loosen it, this can be done by tightening it first,NO MORE THAN 1/16th of a turn, then try to back it out, if it starts to bind tap with the hammer and use more PB blaster, try working the bolt back N forth till it comes out...Stan
Old 05-27-2002, 10:33 PM
I always put sealant on the WP bolts when I reinstall. That way the EG does not get on the threads and cause a future seizure like you are experiencing now.
Old 05-28-2002, 04:08 AM
