steering center shifting?
which would cause the steering center to move? steering rack bushings? any specific loose bolts?
when this car came to me, it was driving straight with steering canted a little to the right but left/right jogging of the steering wheel was still good response. after making a slow left handed u turn, steering center was suddenly about 20degrees to the left.
Old 08-20-2012, 06:04 AM
It might be the bolt holding the steering wheel on has come loose. Depending on the car, you should be able to pop the cover off and see. The bolt requires a 15/16th or 1 inch socket to adjust. This is early to mis 80s 24/44's. GLWR.
Old 08-20-2012, 06:13 AM
AFM #725
Gawernator's Avatar
The socket would be in metric..
Old 08-20-2012, 06:47 AM
yea that would be a 24mm..but i find the 15/16 to fit better. same size as crank pulley
Old 08-20-2012, 07:35 AM
Surely the steering wheel is splined or keyed? I haven't had mine off yet. I wouldn't bet a beer that the wheel is your problem. Tie rods, control arms, ball joints or steering rack mounts loose, maybe even wheel bearings...
You have a dangerous steering issue - put the front end on stands and repair the problem immediately. I have spoken.
Old 08-20-2012, 09:06 AM
yea i know for sure at least my 83 944's steering wheel is splined. this customers's is a 87 951, surely it'd be splined too.
he rarely drives it. but will advise extreme caution
Old 08-20-2012, 09:48 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
The steering wheel and steering shaft are splined, as are the steering intermediate shaft (both ends) and steering rack, the only way these will move is to actually pull them apart.
It may be possible that the PO had the steering wheel off, and didn't get it seated properly before tightening the nut, but that's highly doubtful. But be on the safe side and check it anyway.
Check that the jam nut is tight against the tie rod ends, check that the tie rod is tight in the steering rack. Get the car in the air and do a through inspection of your suspension for loose/worn components....you could have the makings of a very dangerous situation there.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 08-20-2012, 09:52 AM
968 GUY's Avatar
Check the rack bushings.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 08-20-2012, 10:42 AM
yup rack bushing was shot. replaced with ricochet poly's. all is good now
Old 08-27-2012, 05:51 AM
