-   -   Progressively runs poorer until won't start (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/700418-progressively-runs-poorer-until-wont-start.html)
llcullen 08-30-2012 12:27 PM
I just completed a top end rebuild on my 944s 16V 1987.
It had been on blocks for six months, since the belt blew, and I twisted my valves like a cheap group of pole dancers...interesting, but nut upside. Nonetheless, i had the head done, and all was good.
Also, while getting things together, I had the cams done by Web-cams.
When we started it, the motor ran smooth, however, the top end wasn't getting oil. After replacing the one way check valve on the head, all was good.
I drove it around the block, and it ran very well. Then, two blocks later it felt like I was on 3 cylinders. I got back to the house, went around the block a few more times, and parked it. I was able to start the motor a few more times, each time the motor was harder to start. Now it won;t start at all.
A couple of items:
1) new plugs, cap and rotor
2) I cleared the fuel tank, cleaned the strainer, back-flushed the newish filter, and bench-checked the fuel pump.
3) New Master Blaster 2 MSD coil
Any suggestions on what to look for?
LC
txhokie4life 08-30-2012 01:30 PM
Weak battery?
loose vacuum line or leak?
m
Tom944 08-30-2012 02:00 PM
I would check that the rotor screw is still tight.
968 GUY 08-31-2012 05:51 AM
After checking the rotor,I would check the sensors.
