In the Fires of Hell.....
-87 vs 88 NA Head Differences?
I just noticed in PET that the '88 NA head is a different part number than the earlier ones.
Can anyone tell me the differences? I have an '88 head with good valves and an '85.5 one with 8 bent valves. I am wondering what is not interchangeable between the two? Thanks, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
That Guy
Only difference there might be is the pressure relief valve. The earlier style heads were like 2-3 pieces, the later was a 1-piece valve that was removable by removing like a M4 allen head bolt. Cant remember if that was a '88 or '89 thing though.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
1988 944 2.5L 8-v NA 301k
My '88 has the 1-piece OPRV..
Clark's shows the details of the 1987 MY OPRV changeover: Oil Pressure Relief Valve General Information The '88 n/a had the M44/09 engine code with a slight bump to 158BHP in USA through ROW pistons yielding 10.2:1 compression.. Evidently, the '87 had the M44/07 with same bhp..? I did not know that.
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
That Guy
This is the one piece valve i am talking about;
Thanks, Jon. I am thinking that that might be the difference.
I am asking about the head itself, not the pistons or OPVR. So the castings would be the same, sounds like. I will take a look at that relief valve and see if there's a difference. Cheers, Keith
If you look at the Porsche shop manual for Engine, pages 0.2 and 0.6a you will find your answers.
M44/01-08 are 10.6:1 for ROW and 9.5:1 for USA cars (That covers all NA's up through 1987). The 1988 models use the M44/09-10 engines, which are 10.2:1 for both ROW and USA cars. SAE Power output changed from 143hp to 158hp with the compression increase. Cheers, Keith
Seems odd that they would decrease the compression ratio in the Euro cars.
Never knew/saw that one.. Thanks for the Edu!
