Tach jumping
1987 944. Driving to the shop to get the brakes worked on, I noticed that the tach would go to zero and then back to where it was supposed to be. This happened several times on the 5 mile drive. Any ideas.
AFM #725
Could it be a ground problem?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
944 addict
Possible issue with bad cable connection on back of tach in gauge cluster. Also check grounds for bad connection.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Where would the ground associated with the tach be.
Proprietoristicly Refined
Information might be found in the Pelican "Tech Info Center" found on the top of the page ^^
Pelican Technical Article: Solving Strange 944 Gauge Problems... Or in the WSM Electrical Volume IV GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Banned
Sometimes the gauges just get old too. My rpm gauge sticks at zero every time i start the car until and unless i give it a thwack with my knuckle. Never drops to zero after that though, so it does sound lke a loose connection as mentioned above.
Incorrigible
Thanks for that link, John. My fuel gauge always says "3/4" even when full, and when it reads empty, I still have like 7 gallons left. Maybe it is that and not the sender like I thought.
I need to pull the cluster anyway to do something about my extremely dim dash lights as per usual. My last 951 did the same thing with the fuel gauge. Will report back, I may try it all this weekend if I have time. Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
AFM #725
My fuel gauge starts a little above 3/4 when full, goes up to almost full and then gradually works down. I have gotten it down to the "R" mark once, but a low fuel light never came on. i don't know if that means I wasn't low enough on gas or if the light just doesn't work :S
It was some time ago, but I found that if you tap the gauge and it starts working again, then there is probably a dry joint on the tach pcb. I made some suggestions on how to find it and fix it.
Fixed; Intermittent tach cheers Rissole.
944 Alpine White '89 2.7L |
I had the same problem with the fuel gauge and temp gauge reading low. I pulled the gauges out and cleaned the "football" shaped ground connectors. Whole job took less than an hour. Gauges read correctly now.
how hard is it pull the gauges out.
