Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Another Belts post !
CC:
fty
ae1969
mikeb
scottr
Hi,
The problem is that in my country do not exist any qualified mechanic to do this job. Then I contact the father of a friend that was a Porsche Mechanic in Florida to do the job, they told me that he don´t need the tool to the job. He came and take off the head and we change the gaskets, and repair the mixing (oilcooler), etc.
I bought everypart to the the job. But !, the house that solds me the parts sent me the wrong oil seals (turbo), then we can´t finish the job !. 2 weeks ago came to me the correct kit but in this moment the mechanic is traveling and he will return to México until 3 months.
I don´t want to wait 3 months more !
Please help me to do it by myself this job.
I need to install the oil seals, the new pulleys and the belts.
I don´t have the tool and I can´t rent this.
I know that some of you already change the belts without the tool.
I need to know the position of the shafts, etc.
I have a digital camera, then I can post everyday the process.
I have the hayne smanual but don´t says anyhing about this.
Let me know
Regards
Eduardo
1972 914 914-6 gt look chevy 2.8 v6 (928 engine project)
1974 914 916 Look (3.2 webers engine project )
1984 944 Auto
550 Spyder (replica) 914 side trans 2.2 type 1
1957 R50
1981 R100RS
2000 K1200RS
My Page
Old 05-06-2002, 01:23 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Eduardo,
You won't need the tool (p9201) until the end.....but in your case you may have to try and find a better way to retension the belts.....
The cheapest solution may be the krikit tool or you can just go by feel, but that is tricky unless you know what you are feeling for.
I see you have the front end completely disassembled, so you are half way their.
You mention you have the seals, and the belts? Did you get a new waterpump as well?
Well where do you want to start.....pick seal and lets go from there.......
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-06-2002, 02:19 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Wish i could help but my dad had the FEEL to help me with this one!!!! Good luck
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 05-06-2002, 02:31 PM
Scott R's Avatar
Indeed. Balance shaft seals are the easiest, do those first. Be carefull the top and bottom seals are a different size and many kits do not contain the correct seals. The upper is smaller than the lower. When I get home I will get the exact dimensions for you. I also have the front end of mine torn out right now to replace the water pump so we can do this together. When you get to the CAM belt I will help you tension it without the use of tools. It can be done. And in your situation it may be the only solution.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-06-2002, 02:34 PM
Alex:
Thanks for your answer
yes, I bought and already installed a rebuilt water pump from vertex (seal, new thermostat).
We need to go by feel
Yes, I already have the seal and the belts.
Yes, let´s go to the seals ! (please)
I already have removed, then I only need to push it inside the holes ?
Scott:
Thanks for your time too
seals
4 upper balance shaft 30 47 7 right direction
6 crankshaft 38 55 7 right direction
7 lower balance shafy 30 48 8 left direction
is this ok ?
What about the transparent seals ?
Ok, I will wait
FTY.
No problem, thank you.
who is your father
Mike b:
Thanks for your time too !
You got mail !
Old 05-06-2002, 02:36 PM
Mike B's Avatar
Eduardo...Send me an email at mikeybain@shaw.ca ...I don't see any reason to wait 3 months to get your baby working
Old 05-06-2002, 02:45 PM
what is a krikit tool? Thanks.
Old 05-06-2002, 03:16 PM
You don't need that Porsche tool to do the belts. Just do them and tension them and if they are to tight then they make a whinning noise.
Old 05-06-2002, 03:51 PM
Scott R's Avatar
That is good advice! Twist the loaded side 90 deg, That is about the right tension. Like the above post states, if it whines back it off a bit. My auto tensioner on my 87 whines at full extention, so I back it off a bit.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-06-2002, 09:02 PM
Seb928s: Thanks for your advice
Scott R:
You told me that you will tell me the corect sizes of the oil seals, your 87 have the same sizes ?, or do you know it.
I´m still in the oil seals, when I know that are the corecct ones I will install it. I post the sizes that I believe are and the arrow direction.
About how to install the oil seals, I only need to push it inside ?,
or do I need to put grease or a little of oil before install it ?
Let me know
regards
Old 05-06-2002, 10:26 PM
Question
I already install the shafts oil seals with the help of a 1 7/16 socket but I can´t install the crank oil seal ?.
I don´t want to hurt this.
The inside lip go to out (front car direction ) when I wnat to install it.
Also I will need help with all the miss that I have (sprockets), I don´t take out this and I´m not sure where will be go every part.
BUt please 1 I want to finish the oil seals.
Let me know
thanks
Old 05-07-2002, 02:18 PM
Scott R's Avatar
Procedure for the front main:
Remove the woodruff key in the front shaft. (A pair of pliers works well for this.)
Slide the retaining washer off the shaft.
Carefully slide the oil pump drive gear out of the oil pump housing.
Lubricate the seal inner lip and exterior ring.
Insert the oil pump drive gear into the seal.
Slide the seal and drive gear back on to the shaft.
Align the oil pump gear back into the oil pump housing.
Press the seal into the block using a seal driver or a wood block, be careful as the seal is a tight fit and can become bent.
-Scott
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-07-2002, 09:02 PM
Scott R's Avatar
Balance shaft seal sizes:
Sorry for the delay I have been working long hours here they are:
Upper= 30x47
Lower= 30x48
Check them, I have ordered kits for people that have had the same size balance shaft seals in them. If one is not bigger than the other, they will leak!
Also, same procedure on the balance shafts, reomve the woodruff keys and slide the inserts out and apply the seal to the insert the install the insert.
-Scott
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-07-2002, 09:06 PM
Scott:
Thanks, I Will try tomorow.
Sizes; ok, that´s the same that I posted and I already install it.
What bout the size of the main 38x 55 ?
Old 05-07-2002, 10:01 PM
I already install the oil seals.
What more I need to do ?
I know that the mechanic leave sthe engine in tdc and the head too.
I can see the tdc mark in the head but I can´t find the tdc in the engine (auto trans).
Let me know
Old 05-08-2002, 10:16 AM
ae1969's Avatar
TDC marks
are on the camshaft sprocket.............
and on the flywheel. On the back of the engine next to the firewall you will see a small window and you will see the flywheel.... the marking should be -TO- <--- something like that...
You will also have another marking (a notch) at the bottom of the flywheel, and you can see that from underneath.
Good luck
Old 05-08-2002, 11:44 AM
ae1969 thanks
What I need to do now ?
Install the belts plastic housing ?
I can bolt it in the top (cam) but in the bottom I can´t find the bolts if are bolts, the ones that bolt the housing in the oil seal crank housing ?
Then ?
Old 05-08-2002, 01:37 PM
Scott R's Avatar
Install the inner plastic sheild first. Then do the belts.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-08-2002, 02:55 PM
Ok, The plastic cover already installed, the problem was that I have damaged the screw in one of the holes, already repair it.
WHAT I NEED TO DO NEXT ?
BALANCE SHAFTS SPROCKETS
When I turn the shafts always return to the same position with the woodruf key to the top. Do I need to install the sprockets with the heys in this direction and the sprocket aligned with the plastic cover marks ?
If yes I will need to rotate a little to the left the shaft.
Old 05-08-2002, 05:56 PM
Scott R's Avatar
UPPER BALANCE SHAFT
1. Woodruff key groove of the balance shaft faces up
2. Push drive gear with groove code "o" on woodruff key
3. Notch in gear will align with the cover
4. Install bolt, washer and collar
5. Align collar so that the "o" and "u" can be seen in the holes
LOWER
* Same as above but drive gear only has a "U" on it that faces up when installed on the woodruff key.
Coat threads with locktite and torque to 45NM.
Hope this helps its right out of the factory service manual.
Scott
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-08-2002, 06:57 PM
