Is broken odometer common on 1985.5 944s?
Maybe it's just coincidence but as I'm shopping for used 944's for my sister, I've come across 3 cars, 2 of them 1985.5 944's, in which the odometer stopped working.
Is this a known problem? How serious is it?
Thanks.
Old 12-19-2001, 11:39 AM
i'm having mine rebuilt at the moment and the loaner i got from my mechanic has a broken odometer. It's quite common in the 924/944/968 line because resetting the odometer while the car is rolling will strip out a particular gear in there and kill the odometer. I don't know what it's going to cost to have it rebuilt but i've seen the little gear for sale for $40 on rennlist & ebay (a rip off but i've never seen it anywhere else)
CD
1985.5 944 N/A
Old 12-19-2001, 11:55 AM
Thanks, for the reply.
Wow, how about that?! That's a pretty sensitive gear in that odometer. I guess it's not all too bad to fix.
I'd just hate to have my sister start with a car where the odometer doesn't work.
Old 12-19-2001, 12:01 PM
Obin Robinson's Avatar
VDO (the company that makes the odometers) makes the worst odometers ever known to mankind. they suck suck suck suck suck. trying to find one that WORKS is more amazing than one that doesn't.
obin
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car.
Old 12-19-2001, 01:10 PM
Wow, really? That's a very sobering thought.
Old 12-20-2001, 01:14 AM
yep... point of reference... VW and Audi use VDO guages extensively... BUT... they use Motometer odometers and tachs. if you look on the dash of my 1987 Scirocco 16V, you can plainly see how they avoided using those terrible odometers that VDO sold to Porsche for 3 decades and instead went with the more reliable Motometer ones. this is the same case in many audis. BMW doesn't use VDO guages in many of their cars (and i think Mercedes avoided them too, but not 100% sure because it's been a while since i had my Merc).
the amount of 914s, 911s, 912s, 924s, 944s, 928s with WORKING odometers that are the original ones (never replaced) is way less than the ones i've seen with broken ones. they're such a joke that most garages i've been to (and known about) don't bother jotting down the odometer reading because they know it doesn't reflect the actual mileage of the car.
and that's a fact.
obin
Old 12-20-2001, 05:31 AM
One other interesting I thought about is this. If they're known for breaking, I wonder if they can just be plain unreliable.
Like for example, if you're shopping for a 944, and someone shows you a 1986 with only 44k miles (like I saw a week ago), you might be less likely to trust it.
Or is this bad odometer an all or nothing thing -- broken and complete not working, or completely working?
Old 12-20-2001, 09:14 AM
CD
IMO, $40 for a working odometer is reasonable. Apparently, since the market is supporting this price. Also, consider the initial costs to make this. Materials and molds are not cheap. Let us know what your mechanic charges to rebuild yours. If it's more than $40, I'd start to question who is getting ripped of.......
Scott
'86 951
Old 12-20-2001, 11:56 AM
it'll either WORK or NOT WORK. once in a while they will work while driving, then they'll stop working... then a hundred miles later they'll restart. this is the reason why people often do a lot of preventative maintenance when buying a 924/944.
obin
Old 12-20-2001, 01:03 PM
If there's a case where they work sometimes and not work at other times, the end result is an odometer where the mileage is well understated. That's scary, too, when you shop and compare for a new purchase.
Old 12-20-2001, 04:41 PM
If you think VDO odometers are bad, try their clocks!
Old 12-20-2001, 10:21 PM
heh heh, you're right. in general VDO = crap. the only thing that seems to always work are the tachs and the oil pressure guages (though the senders can be fudgy).
what do i think is better than VDO?
STACK!
http://www.stackltd.com
also, the Autometer gauges have a tendency to work quite well:
http://www.autometer.com
obin
Old 12-21-2001, 05:45 AM
Just to clarify: My speedo was broken (worked about 1/4 of the time), not the odometer. When the speedo was working the odometer did too. The loaner i got had a working speedo but the infamous broken odometer.
I agree that it costs money to set up molds for the gears and the illustration looked like a CAD model...it'd be nice to see them made of something more durable...but i guess if the gear didn't strip out something else (more expensive) would.
Has anyone else looked at that gear for sale?
CD
1985.5 944 N/A
Old 12-21-2001, 11:26 AM
The thing that's a nuisance in car shopping is you can't trust any odometer readings. And a carfax report won't help because a low mileages are not carfax exceptions.
Old 12-21-2001, 11:35 AM
I assumed you were referring to odometer. My bad. Tell your mechanic to drop me an email if he wants that gear for the odometer.
Scott
'86 951
Old 12-21-2001, 01:06 PM
The material I use is more durable. Mine is made from a hard plastic where the original is a more "rubberized".
Scott
'86 951
Old 12-21-2001, 01:11 PM
Scott, how hard is it to change the gear?
Old 12-24-2001, 12:55 AM
Not hard. Just a bit involved. Requires removing the instrument cluster and the speedometer and just taking it apart until you get to the gear.
Scott
'86 951
Old 12-26-2001, 11:27 AM
wmcneil's Avatar
i found it quite difficult to replace the gear because my needle refused to budge and i broke it. i bought another speedo and it had a bad gear too.
i managed to replace the gear on my 2nd spedo w/o removing the needle, but it was difficult.
the problem is not the design of the odo, the problem is that this one gear is made of a different material than the rest and it turns to mush over time and eventually breaks up. this is probably hastened by pushing the reset buton, but the trip is disconnected from the stepping motor during reset.
Old 07-05-2002, 01:10 PM
