Send a message via AIM to DustinWayman
Porsche Crest Suspension and steering slop
Hey everyone,
I just bought a 1990 S2 Cabriolet and I am experiencing some suspension slop in it. The A-arms have been replaced 2-3 years ago and I am not sure if it is that or what. when I go over some bumps at some very slow speeds the steering wheel just "clunks" and feels very loose. what do you think that these noises are coming from? I am going to replace all busings as well so if anyone knows which ones I should order it would be greatly appreciated! Thank you all so much for your help.
Thanks,
~Dustin Wayman
1990 Porsche 944 S2 Cabriolet
1975 Porsche 914 1.8 - Track Car
Old 06-10-2002, 06:27 AM
SoCal Driver's Avatar
Wink
Don't forget the steering shaft with the two universal joints. My next project is to replace one of these (or the entire shaft). Eveything else I did today; ball joints, tie rod ends, sway bar and bushings, struts, engine mounts (a-arm bushings were already replaced).
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-11-2002, 07:12 PM
Did that help you a lot? I am ordering new struts this week along with new bushings, joints and a lot of other things as well. I hope that it will fix everything. The power steering rack seems to be great! doesnt squel or leak any fluid so it should be okay, right? Thanks again for all of your help everyone!
~Dust
Old 06-11-2002, 08:05 PM
"Did that help alot?"
I think what really helped the klunk-klunk over dips type noise was the sway bar bushings. Did have a leaking shock on one side too. The ball joints were fairly firm but no where as tight as new ones. Need to reset the castor and toe in.
Most notable change is replacing the engine mounts.
Old 06-11-2002, 09:27 PM
I had bad shock and was doing the same thinkLift the car and check the wheells for a play.
It is also easier to determine the fault.
Good luck
Old 06-12-2002, 04:32 AM
