Mudd's Avatar
Seafoam
Has anyone used Seafoam in their car, and if so what was the outcome.
Old 10-24-2012, 06:26 PM
Fixer's Avatar
I have only heard good things.
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 10-24-2012, 07:02 PM
redstrosekNic's Avatar
It cured a dead fuel injector in an old maxima I used to drive...
Great stuff!
I have only used it in my gas.
Dustin
Old 10-24-2012, 07:15 PM
AFM #725
Gawernator's Avatar
I've heard good things. I was actually about to try and get some. I used the STP full treatment from the local store in the tank once, can't say I noticed a difference. Apparently Seafoam can be used multiple ways. In the oil, the tank or straight into a vacuum tube. I don't know which tube to use that would drain evenly to all cylinders like their instructions say however.
Old 10-24-2012, 07:16 PM
Mudd's Avatar
The full treatment includes all of the above. The video I watched used the brake booster vacuum line. Every thing I have read about it has been favorable. I wonder why it is not more popular.
Old 10-24-2012, 07:37 PM
yea pour slowly into brake booster vacuum while engine running. turn off engine. let soak for 10 minutes, then proceed to smoke up the whole block. warn your neighbors, before they call the fire dept thinking its a fire (yea...it happened)
Old 10-25-2012, 06:30 AM
AFM #725
Gawernator's Avatar
When you say brake booster vacuum line, do you mean where that check valve is? I replaced all my vacuum lines, the one facing front coming from the brake booster, back to the check valve and then to the engine.. or? Speaking of this, I got a bottle of seafoam today, and put a bottle of techron into the tank.
EDIT: What causes the white smoke? i have read that not everybody experiences the big billows of smoke.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-25-2012, 09:40 AM
16vCorey's Avatar
Everyone who puts it directly into the intake (via a vacuum line) experiences the white smoke. That's just the seafoam burning. That doesn't happen when you put it into the crankcase because you're not actually burning the seafoam, and it doesn't happen when you put it into your tank because it's so diluted that there's not enough of it burning at once to cause any noticeable smoke.
You can actually do the same thing with water. I like to put a valve on the end of the brake booster line, hold the throttle at 3-4k rpms, and slowly open the valve to suck in the seafoam (or water). Either way it's basically steam cleaning your cylinders, but Seafoam has solvents (but water is free).
Old 10-25-2012, 11:39 AM
16vCorey's Avatar
Oh, and be careful not to suck too much in at once, because you can hydro-lock the engine, and that's not good.
Old 10-25-2012, 11:40 AM
AFM #725
Gawernator's Avatar
So you use the line with the check valve, right?
Old 10-25-2012, 12:54 PM
16vCorey's Avatar
Yep.
Old 10-25-2012, 01:09 PM
Toofah King Bad
Rasta Monsta's Avatar
Without a doubt, cleans the combustion chamber and ports. Smoke is far more than the Seafoam burning. When I did it on my Jeep, the cloud could be viewed from orbit.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-25-2012, 01:33 PM
Andrew Gawers' Dad
CHICKS's Avatar
Ingredients
CAS # Wt.%
Pale Oil 64742-54-7 40.00 - 60.00 N/Av >15000 mg/kg >5000 mg/kg
Naphtha 64742-49-0 25.00 - 35.00 N/Av >5000 mg/kg N/Av
IPA 67-63-0 10.00 - 20.00 17000ppm 4720mg/kg 12890mg/kg
MSDS: Sea Foam | MSDS Downloads
Naphtha: Normally refers to a number of flammable liquid mixtures of hydrocarbons, i.e., a component of natural gas condensate or a distillation product from petroleum, coal tar or peat boiling in a certain range and containing certain hydrocarbons. It is a broad term covering among the lightest and most volatile fractions of the liquid hydrocarbons in petroleum. Naphtha is a colorless to reddish-brown volatile aromatic liquid, very similar to gasoline.
Pale Oil: A distillate lubricating oil, straw or pale yellow in color, either a finished oil or to be further refined.
If anyone was wondering what's in Seafoam...
Old 10-25-2012, 01:42 PM
AFM #725
Gawernator's Avatar
So Sea Foam is some transcendent form of oil and gas? The can does say 100% petroleum.
Old 10-25-2012, 04:31 PM
curtisr
curtisr's Avatar
The first time I used it I thought the engine was on fire! I did, however, think the whole thing ran a bit more smoothly afterwards.
As for pour location, have a look at this: HOW TO use seafoam properly - YouTube
Old 10-25-2012, 05:52 PM
I believe in it and Marvel Mystery Oil. Had good luck with both.
Old 10-25-2012, 06:15 PM
AFM #725
Gawernator's Avatar
Okay, so disconnect the vacuum hose right before the check valve, take funnel and slowly pour in Seafoam. During this evolution the car just idles, no throttle right?
Old 10-25-2012, 06:31 PM
Marvel mystery oil can also be used in fuel system and crankcase and intake system.Seafoam works great also but be prepared for some or lots of smoke out the exhaust.
Old 10-25-2012, 06:59 PM
AFM #725
Gawernator's Avatar
Can't wait to see the smoke tomorrow lol
Old 10-25-2012, 08:47 PM
Autocross/Hillclimbs
heres when i seafoamed my g20t, my neighbors were thrilled im sure lol - http://smg.photobucket.com/albums/v363/xadioriderx/Seafoam/?action=view&current=WAYSmoky.mp4
i did a big write-up on a g20 board about each way to use seafoam, but i just checked and its only viewable by sponsors.
as mentioned, you can put some in your tank. you can put some in your oil. and you can let your brake booster line slowly sip it out of a bowl: Unhook and Bowl - YouTube
whether you drive it at all with it in your oil is debatable and depends how much you put in. typically you just let it idle for 15-20 min.
let it idle a bit after sucking it up through the booster, then take it for a nice drive!
Old 10-25-2012, 09:48 PM
