Autocross/Hillclimbs
Timing belt - does this look right?
So i am new to the t-belt thing.
in the picture, the pulley i labeled is doing nothing. i can grab it and spin it freely. is that normal? looks like this is the balance shaft belt idler pulley according to a diagram i found.
at that same point on the belt i can grab it and twist about 3/4 of the way around, im guessing thats too loose? i can search to figure out how to tighten it, thats no problem, but i just wanna make sure first.
TIA!
edit - the label should come up in a sec. its the pulley with the nut on the front just NW of the center of the pic.
Old 10-23-2012, 07:58 PM
There should be about a credit cards distance between the belt and that pulley.
Old 10-23-2012, 09:25 PM
okay perfect. what does it do? is there a certain point when it makes contact?
Old 10-23-2012, 10:11 PM
FransB85's Avatar
it stops the belt from flopping too much under load changes. Balance belt should be a little loose, something like 140-180 degrees between thum and index on the long end. rotate the engine a couple of times and re-check.
Old 10-24-2012, 02:47 AM
Toofah King Bad
Rasta Monsta's Avatar
270 degrees is correct for b.s. belt.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-24-2012, 08:55 AM
good to hear! sounds like its about right then. im no pro at checking timing belts, but you can see in the pic (as well as i could see also) there was no cracking. its got 15k and 4 years on it.
safe to wait another year?
Old 10-24-2012, 09:10 AM
FransB85's Avatar
hmm then I should loosen mine a bit maybe, doesn't whine too much though... Need to re-check tensions anyway it's been about 3000 miles since I put on the new ones
Old 10-24-2012, 09:34 AM
I had mine at 225* and it was too loose and hitting the water pump pulley. Now its at 180* and makes noise but doesn't hit.
You also cant visibly tell the timing belt condition until it is pretty much too late. If you are having doubts, replace it.
Old 10-24-2012, 12:19 PM
winter-hater club member
nynor's Avatar
how lucky do you feel? IIRC, three years or 30K miles, whichever comes first.
"COOL PRIUS!" - Nobody Ever
Old 10-24-2012, 12:20 PM
AFM #725
Gawernator's Avatar
Four years? Replace it.
Old 10-24-2012, 01:43 PM
Dr944S2's Avatar
Hi,
the video
https://www.youtube.com/watch?v=o1P0n1DXMto
should give you some answers.
Regards,
Jürgen
Old 10-24-2012, 02:03 PM
