honerboys's Avatar
LOOSE CV JOINT BOLTS (permanent fix ?)
this was the second time these bolts had come loose on the 85 - both times it was the same spot ..drivers side inner joint - the last time they all had backed out leaving my son stranded on his way to school - i figured they had loosened over many years and i had never checked them - so i torqued them down after adding grease and called it good - well now it's less than a year later and i just happened to look under there and three of them had already backed themselves out and the other three had loosened enough to let the joint spray grease all over the place - so this time i'm trying something that i had heard of but never seen done - i drilled through the six bolts and ran wire through them - the hardest part was stitching all the bolts together as the clearance between the bolt head and the boot clamp is small - anyway i'm hoping this is a permanent fix for this problem - i've had no problems of this sort on the other three joints but if they start acting up they'll get the same treatment
84 928 S - SOLD
2012 Cayenne S
Old 10-27-2012, 03:51 PM
honerboys's Avatar
oops forgot the picture
84 928 S - SOLD
2012 Cayenne S
Old 10-27-2012, 03:58 PM
Known problem. Several kits out there to remedy. Ideola's garage has a good one.
I'd be a little worried the drilling weakened the bolt head and you'd risk breaking it off if it didn't want to come out. May not be an issue though. I guess you wouldn't know unless it happens...
Old 10-27-2012, 04:31 PM
AFM #725
Gawernator's Avatar
I ended up torquing them down pretty tight with my wrench and used some loctite on the lower half of the threads, has been holding up perfectly.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-27-2012, 04:38 PM
968 GUY's Avatar
Biggest thing is to make sure the grease it off the bolts and out of the bolt holes. Yes there are better ways to keep the bolts from backing out, but ensuring the threads are clean, using a decent locking compound and torquing correctly and rechecking will probably work just fine.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 10-28-2012, 09:33 AM
968 GUY's Avatar
BTW honer, although your bolts will probably barely loosen, the pic shows at least one incorrectly wired bolt. They should all have the wire pulling to tighten against the next if one loosens. S Sorry but its the aerospace and sub mess showing.
Old 10-28-2012, 09:39 AM
AFM #725
Gawernator's Avatar
Truth! I ran one old bolt in and out of all the threads a couple times to get most of the grease out of the holes. Used 12.9 bolts from pelican with pink loctite and check them once a month.
Old 10-28-2012, 09:53 AM
Got to love aviation... especially when you're lockwiring upside down,working through a mirror with a flashlight with weak batteries.
-1986 944 NA
Old 10-28-2012, 01:27 PM
honerboys's Avatar
968guy - yea i saw and thought the same thing - the problem is there's so little clearance between the bolt head and boot i couldn't feed the wire that way - and i'd have to torque it down way too tight to spin the hole to where i could - i just used some wire i had here - it's pretty thick - maybe some thinner hardened wire would work better - something like a guitar string - i know i could check them more often but it's actually mostly driven by my son
84 928 S - SOLD
2012 Cayenne S
Old 10-28-2012, 03:07 PM
gtroth's Avatar
I never understood why these back out for some and not for others.
When I replaced my axles ~80K mi ago, I cleaned up the threads, applied anti seize to the new cheeseheads that came with the axles, and torqued to spec. I check them from time to time while I'm under there, and they're not going anywhere. No idea why I have been so lucky.
New bolts?
1995 993C4 guards red
1988 944S alpine white
Old 10-28-2012, 04:23 PM
AFM #725
Gawernator's Avatar
Maybe, 12.9 grade bolts by Febi sold by PP, work great..
Old 10-28-2012, 04:44 PM
968 GUY's Avatar
Honer, just an observation, as I said, it wouldn't loosen much even if it did.
There was a juke list of tools to work on some of the aircraft engines included a strap on mechanical third arm and a ratchet with a chin rest.
Old 10-28-2012, 05:57 PM
Tcrate's Avatar
Stage eight bolts are expensive but they will keep those in place.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
1973 Mustang Mach 1 351C
Old 10-28-2012, 06:41 PM
AFM #725
Gawernator's Avatar
Overkill, IMO
Old 10-28-2012, 06:44 PM
