-   -   Can someone tell me where the Aux. fuse box is! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/71399-can-someone-tell-me-where-aux-fuse-box.html)
overkill 06-13-2002 11:39 AM
I have to remove the fuse for the fuel pump so I can depressurize the fuel system so I can change the fuel filter.
Britwrench 06-13-2002 12:41 PM
There is no auxilary fuse box on a 944s. The fuse is in the main fuse box under the hood.
overkill 06-13-2002 02:19 PM
Thanks Britwrentch, I got it. I finished everything I had to do. I did a pretty damn good job too. The fuel filter replacment was the hardest. The nut on the line from the tank was rusted on really tight, so I kept using WD40 and TURP to loosen it. I kept workin it back and forth with the wrenches until it came loose. This guy from next door even came over to ask my advise about staring up a 280z that has been parked for like 11 months, it was cool. Anyway, tonight I have to see whether all my work paid off. If the car has trouble starting then I just get some help from the autocrossers up at the meadowlands. Thanks again.
