Injection- This is about proud
1 Attachment(s)
Hi,
Like some of you already know, I have problems with my engine because here don´t exist an specialist in this old cars and the only one that I can find is and old man retired that continuosly travel but he will return and will be finish the job. But I like to job in the car ! Then I will try to fix by myself until he returns and have fun doing myself. Then, I found some air or vacuum lines lines disconected and I can´t find where will be there connect it. Then I believe that the better way to know id taking out the injection. And by the way look the intake valves to know how I need to install the timing belt. And by the way the way check the air valve. questions 1.- Obviously when the piston 1 is on tdc ( combustion and exhaust) the intake valve in piston 1 will be closed. Then with the piston 1 in tdc and the cam in tdc what piston # intake valves need to be open. This to know if I´, 180° off. |
| All times are GMT -8. The time now is 10:42 PM. |
