curtisr
curtisr's Avatar
Is a 12 mm banjo bolt really 12 mm? :-)
Hi everyone,
Forgive me for asking but, is an M10 X 1.0 12 mm banjo bolt (for the steering rack) measure 12 mm from beneath the head to the end?
I can get these much cheaper at the local farm equipment store but they are not sure of the length.
Why don't I just measure the ones I got? Err, they're still in place and it's bloody cold on the garage floor.
Thanks.
Old 02-19-2013, 04:30 PM
I think they are longer than 12mm. 12mm is only about 1/2 inch. maybe the 12mm refers to the distance from the head to the start of the threads or the oil passage.
Old 02-20-2013, 04:23 PM
I take that back, most of the banjo bolts seem to list the full length. Can you measure the rack fitting to see if this makes sense?
Old 02-20-2013, 04:28 PM
curtisr
curtisr's Avatar
I will and hopefully this weekend. We'll finally get above the freezing mark. Thanks!
Old 02-20-2013, 06:45 PM
Eric
I measured my old one. It was an m10x25 - 25mm is measured from underside of head.
Eric
Old 02-21-2013, 02:43 AM
curtisr
curtisr's Avatar
Thank you, Eric.
Old 02-21-2013, 03:14 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Yeah, just looking at it it ~ twice the diameter so 25mm Nominal Length as measured by Eric is right.
The 12mm refers to the Thread Length portion.
When it comes to Fastener measurement (stud, bolt and screw) unless you got the Specification it was built to, the numbers could be iffy.
Here is CV bolt that is call 47mm bolt by the Supplier Lobro/PP. Nothing on it measured 47mm;
Who Will Live... Will See
