Raa Raa is offline
Red face 924 1977 back wheel-shaft bearings
do the shafts have to be removed to change the bearings & do the bearings have to be pressed in? thanks
Old 11-08-2012, 12:02 PM
1) Shafts must be removed.
2) Wheel bearings are not pressed in, but make sure that you remove the grip rings before trying to remove the inner bearings... If you take a look at the exploded parts diagram, you will see what is necessary.
Good luck, George Beuselinck
Old 11-08-2012, 12:27 PM
Raa Raa is offline
done. thank you.
Old 11-08-2012, 12:29 PM
