16vCorey's Avatar
How much play should the steering rack have?
I'm guessing none or not much at all. I'm working on a friend's '86, and it's got at least an 1/8" side to side play, and the tie rod ends are tight (inner and outer). I don't remember my '84 having that much play at all. I guess I could jack it up and find out, but that requires work, and I'm already up to my ears in that. Is it shot?
Old 11-18-2012, 02:13 PM
968 GUY's Avatar
Is the body of the rack moving, or is the 1/8 play in the steering wheel/ column?
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 11-18-2012, 04:01 PM
16vCorey's Avatar
The play is between the rack and the pinion gear. With the steering wheel/column locked in place I can move the wheels about an 1/8" or so side to side.
Old 11-18-2012, 04:47 PM
9FF 9FF is offline
9FF's Avatar
Use the centering bolt to lock the rack. Then try the wheel again, if it still moves it's your tie-rod ends, if it doesnt move try your steering wheel, if that moves its either your rack or intermediate shaft.
IMO 1/8 is a lot, it's likely your intermediate shaft, the racks are quite bullet proof.
Old 11-18-2012, 05:29 PM
