Mike_944's Avatar
Temperamental Drivers Window
So a few weeks ago the drivers window on my 85.5, 944 stop working. It wasn't until a week later that it started working like nothing happened. Now it's back to not budging.
Anyone know what could be causing this?
Old 11-05-2012, 06:50 PM
FransB85's Avatar
If it's only 1 window I'd say it's the switch. Take it apart carefully so the little balls don't go flying, sand off the corrosion of all the parts and put it back together. A good trick is to use a piece of scotch tape over the balls. You lick the tape once or twice to make it less sticky. That way you can just pull it out before clicking the two halves of the switch back together and the balls don't fall out when you turn it upside down. I know it sounds weird but it works like a charm.
See clarks garage for the rest of the how-to.
Old 11-06-2012, 12:11 AM
AFM #725
Gawernator's Avatar
Sounds like the switch to me. I fixed two of my switches by taking them apart and removing the corrosion with a pencil eraser. To be honest I'd just get new switches if you have original ones, they'll be a lot smoother feeling.
Old 11-06-2012, 07:06 AM
Oh man...What now?
iplagolf's Avatar
I used s spot of grease to hold the BB in place, helps to lube it too...
Me and Porsche's go together like cocaine and waffles. Those don't go together. Well, peanut butter and women. Don't you mean jelly? You put jelly on women? (Ricky Bobby, Talladega Nights) 1985.5 944 Alpine white
Old 11-06-2012, 08:54 AM
Dave Colangelo's Avatar
Clean up all your grounds, many of the electrical issues in these cars are related to corroded grounds. I like to take the bolt out, clean it off, sand all the tabs to fresh copper and then sand the chassis down to clean metal around where the bolt goes. I would also clean all the contacts on the switch. It may be worth it to pull the switch and bench test it. Some contact cleaner is also in order.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 11-06-2012, 10:00 AM
AFM #725
Gawernator's Avatar
Seriously though, all you need to clean the contacts is an eraser. Old electrician mate's trick.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-06-2012, 10:43 AM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Switch the switches to see if the passenger switch works better on the driver's window.
If not, then troubleshoot the motor.
Licked scotch tape worked like a charm.
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 11-06-2012, 01:13 PM
Mike_944's Avatar
I've already tried cleaning the switch and trying the drivers switch in the passenger slot. That is not the problem as the drivers switch moves the passenger window.
Which grounds would I clean? Where are they located?
Thanks everyone for your responses. It was 93 degrees yesterday and I have no AC so having my window work is a must.
Old 11-06-2012, 03:29 PM
I would guess that both switched in the drivers door have the same ground. Sounds like the issue could be the motor.
Old 11-06-2012, 03:53 PM
VirginiaF1's Avatar
Porsche Crest
So you also tried passenger SWITCH to run DRIVER window? Result?
If crappy, then ya motor.
Best wishes for success
Let us know progress
Old 11-06-2012, 06:26 PM
Mike_944's Avatar
If it's the motor then why would it sometimes work and sometimes not? Wouldn't it just not work at all?
Old 11-06-2012, 10:45 PM
Motors have contacts (brushes) in them that can wear out or get corroded.
Old 11-07-2012, 04:15 AM
VirginiaF1's Avatar
Porsche Crest
My driver motor is exhibiting the same intermittent symptoms..
It was replaced oem 12 years ago.
I will clean its contacts/brushes but fully expect to have to replace next year.
Old 11-07-2012, 07:00 PM
FransB85's Avatar
An important factor in wear of these parts is mechanical resistance. You need to keep the guide rails and rollers clean and lubed, if the motor has to work against a lot of resistance the brushes are 'eaten away'. If you replace the motor make sure the window it operates is running smoothly or you'll cut your motor's life in half.
Old 11-08-2012, 01:46 AM
VirginiaF1's Avatar
Porsche Crest
Good call..
Every month my guides get cleaned out with qtips then a light silicone lube.
Old 11-08-2012, 06:53 PM
AFM #725
Gawernator's Avatar
Originally Posted by VirginiaF1 View Post
Good call..
Procedure?
Old 11-08-2012, 06:57 PM
Tags
frustrating , not working , stuck , window
