Power Windows not working
I did some troubleshooting tonight and found no power to the fuse block for the power windows. Should there be power there with ignition on or is the fuse only powered when the relay is activated? No click at the relay, no voltage drop at all when any of the switches depressed, no power at the switches. At first I was ready to go after the grounds, but without power the grounds don't matter a bit.
Give the window trouble shooting tips from Clarks a try.
Electric Window Troubleshooting If you get down to taking off the door panels to inspect the motors, look at the window regulator rollers. Rennbay has a kit to replace. Porsche 944 window regulator plastic rollers kit GL John |
| All times are GMT -8. The time now is 02:05 PM. |
