16vCorey's Avatar
Best timing belt/BS belt/rollers/water pump kit?
I know the question was asked before, but I can't find the thread. I'm digging into an '86 944 with unknown history, so I'm changing EVERYTHING. Does anyone sell everything in a kit?
Old 11-08-2012, 01:46 PM
Andrew Gawers' Dad
CHICKS's Avatar
I think I may try this kit when mine are due. 1986 Porsche 944 Base L4 2.5L > Engine > Timing > ES#2574802 ECS Ultimate Timing Belt Kit With Water Pump - 94410515704KT4
You can always piece everything together here at Pelican, just not sure of the price difference.
Old 11-08-2012, 01:55 PM
Toofah King Bad
Rasta Monsta's Avatar
Missing BS seals, cam seal and bolt, crank seal.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-08-2012, 03:03 PM
Here is another kit that has all that you need.
944online.com - Find Parts For Your Porsche 944 And Get Your Car Back On The Road.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 11-08-2012, 04:34 PM
AFM #725
Gawernator's Avatar
The second kit is actually less expensive too.. hmm. Normally 944online is more expensive on parts than other places, I wonder if it's cheaper for everything at PP.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-08-2012, 04:56 PM
Andrew Gawers' Dad
CHICKS's Avatar
The 944online kit (that was posted) has a rebuilt pump vs ECS's new pump. No idea where the 944online parts came from, but from ECS, "Our kits are assembled with quality rollers and tensioners from Ruville, and INA. Balance shaft belts are constructed by Gates, and the timing belts are by Continental. All water pumps are brand new units from LASO, sealed with quality gaskets from Victor Reinz."
Old 11-08-2012, 05:14 PM
AFM #725
Gawernator's Avatar
So INA is a good company? I hear not so good things about the "INA Lifters"
Old 11-08-2012, 06:43 PM
I believe INA is the only company that makes the rollers currently.
Also Ian at 944 online will not sell anything that isnt quality.
Old 11-08-2012, 06:49 PM
Zims will sell you the best-quality rebuilt WP and the same belt kit for half that price. You don't need Porsche coolant.
Old 11-09-2012, 09:04 AM
Proprietoristicly Refined
John_AZ's Avatar
I agree.
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-09-2012, 12:58 PM
AFM #725
Gawernator's Avatar
944 Naturally Aspirated Water Pumps Only $95? What?
Old 11-09-2012, 01:44 PM
GreenWater's Avatar
Also check out www.only944.com. They don't have a kit for all these things but it's cheaper to get they separately. Comes out to about $430
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
John_AZ's Avatar
Originally Posted by Gawernator View Post
Probably the best reputation for rebuilt on the web.
Read the disclaimer on cores. They do not take junk for cores.
John
Old 11-09-2012, 03:07 PM
AFM #725
Gawernator's Avatar
Zim's Autotechnik Cam/Balance Shaft Belt & Roller Kit, 944 -86 late
The question is, how can one tell if you have the late style WP or not? My records show a WP bought for like $395 so I'd assume it's a new unit?
Old 11-09-2012, 03:11 PM
John_AZ's Avatar
The "late" water pump kit has a 46mm cam belt idler roller.
Early cars with WPs not upgraded had a 32mm cam belt idler roller.
OR---if your WP has the silver belt guard it is normally the "upgraded" late pump (either rebuilt or brand new-usually LASO, hopefully not a cheap Asian) with the 46mm idler roller.
FYI Porsche TSB says if your current 46mm roller "feels" a little gritty or noisy it is probably good. Just a "feature" of the 46mm roller.
John
Old 11-09-2012, 03:22 PM
GreenWater's Avatar
That sounds like a great feature! If my roller is quiet(doesn't have that feature), can I add it? Does Porsche sell that Feature by its self, or do I have to buy a new roller? I will have to look into that.
84 944
Old 11-09-2012, 05:08 PM
