Charcoal Canister
I have a 1987 924S. Do the charcoal canisters go "bad"? I suspect that mine has been overwhelmed by an overly rich running engine. I see they are fairly expensive to replace so not wishing to waste money.
thanks, James |
AFM #725
I was wondering what they are even for ..lol
http://wiki.answers.com/Q/What_does_a_charcoal_canister_do_on_a_vehicle
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com Last edited by Gawernator; 11-13-2012 at 02:12 PM.. |
Fuel tank breather used for emissions. One side goes to a bunch of solenoids in the engine bay the other vents to atmosphere through a tube under your rocker panel.
The solenoids vent the tank through there when the engine isn't running and vent it through your intake when it is running. You will know when its not working, when you fill up with gas it bubbles back at you through the filler hole. The air in the tank cannot escape fast enough through the canister. This only happens on a newer gas pump though, the type that seals the fill hole will a rubber shield. |
Redline Racer
I'm sure they do, but who cares? The EPA maybe, but they don't test it...only makes sure it's there. There is a vacuum thermal actuated valve that opens a vent to send the recovered vapors to the intake once the engine is warmed up.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
