assembly lube preference
as the title suggests, what is the general consensus on preference.
A good start would be what is listed in the WSM. I don't have mine right now. Do a search on this and other forums, i'm sure there is plenty of opinions.....kind of like the best oil argument.
http://forums.pelicanparts.com/uploa...1353013112.jpg
http://forums.pelicanparts.com/uploa...1353013315.jpg Follow your owner shop manual .:D |
Assembly lube...
I used to use Lubriplate. |
I used the Sta Lube and it worked fine.
I haven't needed to assemble anything in the 944 requiring assemkbly lube. That said I have used Sta Lube in several other engines. It's recommended by many engine builders.
Clifton |
Sta-Lube is not at all bad stuff, but I am using Redline these days... :D
http://www.redlineoil.com/content/im...roducts/77.png They also have a more liquid version I've been happy with too, looks like raspberry syrup... http://www.redlineoil.com/content/im...oducts/136.png |
thanks, picked up some Sta-Lube, that is all they had. wish me luck!!
some guys like assembly lube - others stay clear of it on purpose and only use break in engine oil.
i always used isky lube. |
| All times are GMT -8. The time now is 11:01 PM. |
