Ignition key won't turn
My key is getting hung up in the ignition. I have tried jiggleing, WD-40, Carburetor cleaner, letting it dry and putting graphite in it. It still hangs up but eventually will turn. Is there a discussion on this subject on here somewhere or on a different website. I have tried contacting locksmiths but none want to touch it.
1978 924 The Grey Ghost - 18,000 miles and counting 1987 944 Black Betty - Bringing back from years of abuse |
1983 944 N/A
It could be a worn key , I deal with it at work all the time.
I might have a spare ignition switch and key available if you are interested.
I am interested if I can't find another solution.
Quality
Don't ghetto your car with a different key. Get a new key cut (cheap, Porsche will do it based on VIN). If that doesn't help, get a replacement ignition and have it match the original...
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
AFM #725
My car came with a seperate key for the ignition and locks
Looks like the whole ignition assembly was replaced the same time other work was done, like WP and belts.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Read thru the link below and you'll find the DIY info with pictures no less.
How to remove the ignition switch of 1988 944NA? Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
