-   -   How to fix 924 odometer (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/717852-how-fix-924-odometer.html)
Ater 11-19-2012 03:07 PM
The speedo works just the odometer don't turn ?
bennkishh 11-19-2012 03:08 PM
The gears almost always strip. As far as I now, there are replacement gears, and the replacement is fairly simple. My entire speedo/odo gage is shot.
Ater 11-19-2012 03:11 PM
How do I remove this do I need to take the whole dash out?
bennkishh 11-19-2012 03:13 PM
I'm not sure, I havnt really looked in to it yet. Maybe tomorrow ill take a peek at it.
968rz 11-19-2012 04:49 PM
You can remove just the gauge cluster, then the speedo from it (some have had to remove the steering wheel but if you're careful that's not really needed)
ernie9944 11-19-2012 05:37 PM
Your 924 & the early 944s will have the same gauges cluster so maybe you could use Clark's Garage Home Page as a guide (enter Garage Shop Manual).Scroll down to Gauges -Pre -1985.5 gauges removal.GL:)
nightheart 11-19-2012 05:38 PM
Clarks garage. If you don't know it by now, you should.
odo repair
Odometer Repair
Home page. goto "garage shop manual."
