marko's Avatar
Stock replacement front springs for S2 without lowering?
Is there no one that has new replacement springs for S2?? I'd just like some #200 replacement springs without lowering or needing spacers.
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 11-21-2012, 04:07 AM
Toofah King Bad
Rasta Monsta's Avatar
Pelican Parts - Product Information: SP944-220S
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-21-2012, 08:50 AM
marko's Avatar
It says from 1976-88, mine is a 90.
Old 11-21-2012, 04:02 PM
murrayg's Avatar
Won't work on an S2, smaller diameter spring.
Gord.
Scotch Village (near Halifax)
Nova Scotia, Canada
Old 11-21-2012, 04:35 PM
Banned
also watch out for those springs, i bought them, and they were way way way way too short. pelican said that they requires some spacers - 80 bucks.
might as well just get ground control front coilovers for that kind of money.
Old 11-21-2012, 04:44 PM
ernie9944's Avatar
Why don't you opt for a pair of (Weltmiester 250 pds) from Automotion,they will only lower your S2 approx 1.5" front which is not extreme.Then you could lower the rear 3/4" by adjusting you camber plates.This will be the most inexpensive way of doing thing.Agree that that ground control front coilovers are nice but it will cost more.
Weltmiester 250 pds
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-21-2012, 05:53 PM
RedBaron's Avatar
Get a set of used 951 (87+) shocks and Weltmeister springs with spacers. That's exactly what I did. The S2 shocks require a different diameter spring.
Old 11-21-2012, 08:16 PM
marko's Avatar
I already have new struts installed with the original springs. I still have a lot of roll when cornering. I'm guessing my springs are probably worn out after 250k miles. Control arm bushings are definately worn out, but I have some powerflex bushings ready to be put in. I just need some new 200lb springs that will fit, 250lb might be too harsh for a daily driver. Used suspension parts are out, I've gone that route too often with disappointments.
Old 11-22-2012, 02:56 PM
