AFM #725
Gawernator's Avatar
Wheel Balancing
I think my car may have lost a wheel weight or my tires are worn, I did just rotate the fronts. Finally finished stripping the red paint off and the aluminum looks nice and clean. It needs to be polished fully but I am in finals! Anyways, the past couple days I've been noticing slight vibrations, intermittent when driving on the highway. Really seems to be a balance issue, it's very speed specific between 63-68ish or so. Tomorrow I was going to have Sears balance all the wheels while I'm working (it's connected to my building), my question though is it necessary for wheels weights to be on the OUTSIDE lip of the Fuchs? I never see it on pictures of other Fuchs. I think it looks pretty tacky and I also realized it's gonna be awkward trying to polish the wheel correctly with these ******* stacked weights randomly on the outer lip.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-06-2012, 08:42 PM
AFM #725
Gawernator's Avatar
Why would anybody put them on the outside in the first place? ....
Old 12-06-2012, 09:33 PM
Dave Colangelo's Avatar
Different places do it differently, it also depends on what weights they have on hand and what values they are. You may also want to consider an alignment if that does not do the trick.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 12-06-2012, 09:56 PM
AFM #725
Gawernator's Avatar
LOL. Remember, we see everything. No, my second part-time security job
Old 12-06-2012, 10:26 PM
Oh man...What now?
iplagolf's Avatar
I've had my front wheels balanced twice now. Both times I too have a slight, very slight vibration at the very same speed range as you have. Different amounts of weights were applied each time but in the same general area. I've just been living with it, but now it's got me thinking that there is something else going on since I've seen your post. When you get them rebalanced ask Sears to note what's there now and what they did. I'd be interested. Thanks, Fritz
Me and Porsche's go together like cocaine and waffles. Those don't go together. Well, peanut butter and women. Don't you mean jelly? You put jelly on women? (Ricky Bobby, Talladega Nights) 1985.5 944 Alpine white
Old 12-07-2012, 06:02 AM
flash968's Avatar
tire balance can be a tricky thing. sometimes you have to rotate the tire on the wheel to get it. road force balancing is always the best way to go, but more expensive, and hard to find a place that can do it.
as for weight locations, not putting them on the outside can be a compromise. it really depends on how bad it is, what the offset of the rim is, yada yada. again, sometimes you have to rotate the tire on the rim itself, to move the weight of the tire around to a spot where it can balance out better.
Old 12-07-2012, 06:06 AM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Porsche Crest
Howdy Gaw..
What are the age and make/model of your tires?
Same here on the 65mph vibes.. even after wheel balancing .
I run SP Sport A/S @ 215/60/15
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 12-07-2012, 06:32 AM
DinoDanny's Avatar
Ah, the notorious 944 65 mph wheel shake. I've had it with both of my 944s. Supposedly these cars came from the factory with one of the wheel studs painted yellow. This was the stud that you put the hole closest to the valve stem on as well as the wheel lock nut. If I remember correctly this is the stud opposite the 2 screws on the hub of the brake rotor. I have had some success mounting the wheels with this method. Also the weight of the wheel lock nut is different from the other nuts. Its position can make a difference.
Danny
1987 Porsche 951
2003 Kawaski ZX-12R
2008 Kawasaki Concours 1400
Old 12-07-2012, 07:29 AM
AFM #725
Gawernator's Avatar
Wait a minute. I HAD the original lug nuts including locking... But I got a set of new chromed steel ones for $28 and just recently mounted them. Could that seriously make a noticeable difference?!
Old 12-07-2012, 07:49 AM
Oh man...What now?
iplagolf's Avatar
OK, on that note my locking lug is sans the locking innards...I wasn't worried about the lighter lug nut due to its proximity to the center of the axle. Could this few grams lighter lug throw off the balance of the wheel at a certain speed range?
Old 12-07-2012, 07:55 AM
flash968's Avatar
not likely, but porsche did do something weird. they marked one stud red, and wanted you to put the locking lug on it, and opposite the valve stem.
Old 12-07-2012, 08:04 AM
something I've noticed, whenever I had wheels balanced or aligned by a normal place it's never completely fixed. When I took it to a Porsche specialty shop it came back PERFECT. Probably irrelevant to the convo but I thought it was important to share. Also, I had a vibration upwards of 60 that seemed to smooth out towards 90, the alignment by the specialty shop fixed it so if the balancing doesn't do it then maybe it needs to be aligned. I have aftermarket wheel locks, one on every wheel, and mine's completely smooth. I just stick them on any stud
ernie9944's Avatar
Originally Posted by flash968 View Post
tire balance can be a tricky thing. sometimes you have to rotate the tire on the wheel to get it.___ ( road force balancing is always the best way to go),____ but more expensive, and hard to find a place that can do it.
+1 about road force balancing, like mention the only problem is that only a few shop can do it rigth.Personally I always did go with road force balancing on all my Porsches.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 12-07-2012, 10:56 AM
AFM #725
Gawernator's Avatar
Originally Posted by VirginiaF1 View Post
Howdy Gaw..
I still have the PO's tires, have to wait for them to run out of tread before choosing my own. I have staggered sizes, 205/55 in the front IIRC and 225/50 in the rear. Dunlop directional tires... I will double-check that.
Old 12-07-2012, 11:53 AM
AFM #725
Gawernator's Avatar
None of my studs appeared to be colored? Where would I find the markings?
DinoDanny's Avatar
The red paint has probably long since worn away.
Danny
1987 Porsche 951
2003 Kawaski ZX-12R
Old 12-07-2012, 12:27 PM
flash968's Avatar
yeah - it really doesn't matter which stud is red. the idea was to put the lock on that stud, and the valve stem opposite that. it's supposed to help balance
Old 12-07-2012, 12:30 PM
AFM #725
Gawernator's Avatar
Holy crap. $60 to balance all four, they put the weights on the inside too. It fixed the steering wheel vibration totally! Car feels like it drives a little bit straighter as well.
Old 12-07-2012, 12:39 PM
FrenchToast's Avatar
Interesting. Why would this be the case though? There is nothing in the hub to suggest an engineered imbalance. Rotors are usually balanced from the manufacturer.
Holy smokes that's a lot to balance four wheels.
Did they replace the poly-syncratic rhythm optimization bushings?
Take care!
______________
Happy Holidays!
Old 12-08-2012, 07:33 PM
AFM #725
Gawernator's Avatar
Yeah, I was kinda smacking myself afterwards realizing I could have it done for free at America's tire, since my cousin is a senior manager. At least I'll have free alignments.
Old 12-08-2012, 08:15 PM
