-   -   dumb oxygen sensor questions (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/720875-dumb-oxygen-sensor-questions.html)
Bukowski 12-01-2012 11:58 AM
if I use penetrating oil on the O2 sensor when removing it, how should I rinse the residual oil out of the threads on the exhaust pipe?
on a Bosch 13011, what is the signal wire in the plug end?
will a torque wrench and O2 sensor socket work in that area, crowsfoot, or anything else?
Gawernator 12-01-2012 12:04 PM
I sprayed some PB blaster. Used an adjustable size wrench and it screwed off really easily, first try. Luckily. Then carefully inserted the new universal sensor. Tightened to snug.
John_AZ 12-01-2012 03:33 PM
The 2 white wires are the heater wires---the black is the signal wire.
On the O2 sensor cord---at the connector plug end--the single "male" pin is the signal.
John
