Dex/Merc instead of Dexron III for Power Steering?
Hey All - What's a good replacement for Dexron III for my '87's power steering fluid? Everything I've read says our cars take Dexron III but I can't find it in stores anymore...Dex/Merc being one replacement.
For the time being, I just need something for topping off (found reservoir leaking) and later flushing. |
Where are you located? I've seen generic dexron III replacement at all local stores
A couple of possible replacements compatible with Dexron III are Dexron IV or Synthetic ATF such as Deep Purple.
Deep Purple may cause Smoke...on the water!
it will turn you into a smooth operator.
I'm using (Superpro RXL1 ATF+3) from Chrysler without any issues.It's the same as Dextron III which is a GM product.:D
The autozone replacement says it's compatible for cars that require dex3 but I don't know if I should be mixing that in |
Redline D4 is Dex III compatible and very robust.
If it says for DEXRON III applications it's probably good. I am using generic no name O'reilly's store brand dexron III ATF and it works.
Thought the same thing.. Good on ya mate. http://forums.pelicanparts.com/suppo...ys/drummer.gif |
thanks for all your comments
...once last thing, so is it okay to mix/top off with the old, or should I flush it out? at least at a minimum, perhaps I'll draw out as much as I can with the baster I just bought. |
Flush it.
Your choice on use but I am not comfortable with any leak sealer in the PS unit. http://forums.pelicanparts.com/uploa...1355172599.jpg Also on the recent trip to WalMart Superstore found they did not carry any 20-50 conventional oil. Most all oil was synthetic --mostly 10-30 or 10-40 in various brands. Not even Pennzoil 10-40 for the Jeep. John |
Regarding the 20W50...I've never found 1+ quart sizes in stores for this type, only 1 quart. Recently bought 3 oil change size jugs on Amazon (Castrol GTX) |
Repeating my answer for the post: Castrol Info on Dex/Merc: Castrol USA - Transmax DEX/MERC The AutoZone fluid you found is OK if it says compatable with Dexron III. And for the Synthetic members: https://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_1_Synthetic_ATF.aspx# J_AZ |
From the bottle backs (underlined parts I reference above): Standard - "Recommended for use in all 1983 to 1996 Ford automatic transmissions. Use Castrol Type F ATF in applications calling for Type F. Do not use this ATF in applications calling for Mercon V, Mercon SP or Mercon VI." For Honda, Toyota, Nissan, and Other Imports - "Recommended for use in vehicles that require: Honda, Acura - ATF-Z1, DW-1 (except in CVTs), Toyota, Lexus - Type T, T-III, T-IV, Nissan, Infiniti - Matic-D, Matic-J?, BMW - LT71141, Mitsubishi - Diamond SP-II, SP-III, Volvo (all specifications) .....Also meets requirements of: ATF+3, ATF+2, ATF, Ford Mercon, Ford Mercon V (Not for use where Mercon SP or Mercon LV is required), General Motors Dexron III and prior (Not for use where Dexron VI is required)." |
Thanks Todd,
I bookmarked the post. J_AZ |
