AFM #725
Gawernator's Avatar
Pentosin PS Fluid?
I came across this thread: 944 Online Forum - The Porsche 944 Forum For The 944 Enthusiast.
Mentions using Pentosin hydraulic fluid, instead of ATF/Dexron III
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-14-2012, 01:00 AM
9FF 9FF is offline
9FF's Avatar
It's spec'd on the later cars, my 996 uses it and NAPA stocks it, oh and it's expensive. I don't know if it is compatible on 944's, it's not specified by Porsche for early cars just for later 99+ ZF racks. Might be ZF changed the ps seals on the later cars so that Pentosin is ok. It's something only ZF would know I suppose. Need more research.
Old 12-14-2012, 04:24 AM
I saw that post also and did a little more research. It appears that the reason why Porsche changed to using the Pentosin PS fluid was that ZF determined that the ATF was the major cause for seal failures. There have many that have changed from Dexron to Pentosin and have report no issues whatsoever.
Old 12-14-2012, 05:54 AM
AFM #725
Gawernator's Avatar
NAPA down the road has Pentosin products, maybe it'll be a good idea to switch whenever I need to overhaul the system
Old 12-14-2012, 10:18 AM
Mein Gott!
Panzer909's Avatar
No need to go out of your way to get it, IMHO. I run into ads for that stuff in all the Bimmer catalogs as well. A decent spec ATF picked up at the local Pep Boys will do the job just fine.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 12-14-2012, 01:45 PM
AFM #725
Gawernator's Avatar
I'm using generic store brand O'Reilly's ATF - Dexron III spec
Old 12-14-2012, 03:01 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Use either the CHF 202 (used by Porsche from 2006 on) $16.99 per liter, or the CHF 11S (used by Porsche from 1990 to 2005) $21.99 per liter. These are hydraulic fluids made for especially power steering, load leveling systems, etc.
Pentosin ATF-1 is not recommended for power steering systems.
Pentosin also recommends flushing the power steering system prior to using either of these products...these are synthetic oil based products, and will not function to full capability if mixed with fossil oil based fluids.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 12-14-2012, 11:39 PM
