Idle question/survey
I wanted to take a quick survey regarding idle. My car seems to idle really low when I first start it in the morning. I have a new DME temp sensor and a brand new TPS. My first thought was maybe my new sensor is no good. Today I unplugged it right after cold start, and it works just fine as the car really ran crappy till I plugged it back in. Maybe I don’t have an issue and just have a motor mount on the way out causing the lower idle at start to seem more violent than normal. At cold start I idle at 700 RPMs. When warm 900. What is everyone else seeing…….
Proprietoristicly Refined
'88 cold start ~950rpm. No difference cold, first morning start or hot start during the day.
'87 cold start ~1050rpm. Same as above, cold or hot. Got the car at this rpm and never adjusted-just works well. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
AFM #725
~950 almost always
950.... all day every day
Hmmm. I wonder what causes mine to be 200 RPMs less till warm. Electric air valve right behind air filter? Auxiliary air valve? I cleaned that with carb cleaner and WD-40. How can I test functionality of these two items?
Just thinking out loud
I have never checked the actual idle rpm myself, but the last time it had to undergo the required state stuff, it was 895 rpm. That was in 2006, but I don't know how accurate their stuff is. The tach has read the same since 1991, hot or cold, there is no difference. It does, and always has had the infamous dip or "shutter" the early cars have after getting off the gas. When that happens, it drops to around 600rpm and bounces back to normal.
The idle speed doesn't increase when the ac is turned on either. It draws it down some, maybe to 850rpm. One thing that concerned me years ago was a hissing sound at idle. It sounds like a vacuum leak or a PCV valve. However, it has always done so, still remains the same, and I intend to leave it be as long as it runs great.
83 944 91 FJ80 84 Ram Charger (now gone) |
my S2 is 950, does dip a little when you hit the AC.
Incorrigible
Cold, 800 for just a few seconds, then 950 very consistently for mine.
Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
1988 944 2.5L 8-v NA 301k
'88 n/a 944 8-valve..
Idled poorly at 850 when I bought it.. Adjusted idle screw to 1100 hot or cold, ac on or off.. Purrs like a dozing lion..
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
Shadetree Technician
For my '83 on a cold start, I get 850 or so for a couple minutes until it warms up, then 950 or thereabout.
on the 84 it's lower on startup if it's below about 60 degrees - around 825 - after 2-3 minutes up to just below a grand
84 928 S - SOLD 2012 Cayenne S |
AFM #725
thanks everyone, i guess mine is not to terribly different. i will stop worrying about it
