please don't let it be the DME :(
hey guys..
So I have an 84 944 just got it back from paint.. and it was running fine.. right up until today. I turn the key, lights come on. Start the ignition, there is a light click/thump/noise, kinda sounds like the starter trying to engage then nothing. No power, nothing. it did this once, disconnected the battery, waited and reconnected and it started. Got it out of the shop, got the new car in and went to start it again, did the same thing, except this time it didn't start.. luckily its a light car so I got it back in the shop.. it about to storm here in Iowa.. any idea whats wrong? I really hope its not the DME.. /: I've disconnected the battery in case its something really bad, but my fingers are crossed..
Check all of your grounds for tight connection.
Check the battery positive connection and the starter and alternator connections.
Good luck, George Beuselinck |
Proprietoristicly Refined
Check the charge on the battery. If the car has been in the shop long it may have discharged when interior lights/doors were left open.
DO NOT JUMP---take the battery out and charge. If you jump with a dead or low battery you can fry the DME---or maybe it is too late.... GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
its not the connections, it started fine this morning when I took it out of the shop, its like the juice is going to the starter and then its blowing a fuse.. I disconnect and reconnect the battery and I've got power again but it the same story if I try and start it.. /:
The starter is a direct connection, there are no relays in that curcuit. If you have power to the starter solenoid when you turn the key and it will not turn chances are your starter solenoid is toast.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
+1 on what 9FF said. If you are blowing fuses you either have a loose connection or you have have a bad solenoid.
Sounds like a bad connection, top side check battery cable clamps, battery ground cable to firewall connection. Love the vehicles in the background!!!!!!!!!! Studebusters drive me wild!!!!!!!!!!!! I used to have deuce and a half with a dump bed on the back and winch on the front, used it when I cleared my mountain side homesite. What a beast it was and built by Curtis Wright Corp. (Studebaker). Is the Studbuster truck bigger then a half ton? I can't tell from the picture.
I'll crawl under and see whats going on
is there a write up on how to fix a DME?and yes those are Studebaker I think its a 3/4 ton? not really sure, that m35 is also a Stude, my father collects them :P lol beautiful car too bad they went under.. well except the avanti
Check the battery charge with a volt meter. If the battery voltage is below 12 volts it needs to be taken out of the car and charged. It should be somewhere between 12.4 and 12.8 volts after a full trickle charge, depending on its age. If it is below 12.2 volts or so after charging it is on its last legs. Once you have a good battery, if it still doesn't start, proceed to trouble shoot the starter, cables, etc.
If it does turn out that it's the DME, you might check these guys out. They helped a Boxster forum member with his car's computer and imbolizer. Prices seem reasonable. They would be the first ones I'd call if my 986 DME goes bad. http://www.ecudoctors.com/
1988 944 2.5L 8-v NA 301k
Howdy John.. Just to educate, why aren't modern cars' CPU fried when/if a dead battery gets jumped.. Thanks!
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
Hi Mikey, I'll postulate. The early Motronic DMEs had basic manufacturing flaws not found in later years & newer cars. Poor solder flow, lack of circuit protection, component and circuit structure not designed for surge in amps+++ . Water damage. Just a few ideas. J_AZ
AFM #725
How do you define "early" and "late" Sir John?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Mr. Gawer,
Sorry I was not clear. VirginiaF1 asked about the "modern" cars and I should have been more specific than saying "later years" . The DMEs in the 944 series from ROW '82 to '91 seem to be the most prone to failure or abuse by the owners causing failures. I would refer to these cars as the "early" series. J_AZ
well gents its was the DME
luckily I have a spare and luckily Specialized ECU Repair fixes them and they have a 5 year warranty
