hatch spoiler woes
So my 951 when I went out to defrost it this morning I noticed the corner of the spoiler where it meets the glass on the "tray" part near the drain holes has lifted, I heated the area thinking ice got under there, but stayed there. Can I remove the hatch spoiler and re seat it?? It looks like somes one changed it at some point at its all philips heads where the screws are. I've never had this happen on any of my 944s or 924s, so I'm curius about how the hatch spoiler goes together etc, I couldn't find any links to how to reseat it or remove it. Thanks in advance!
Mark S. Certified Porsche Newb
Alea Iacta Est.
1987 924S 67k miles, all stock besides weltmiester Throttle Cam
87 944 Turbo shes got a few goodies. New DD
Old 12-29-2012, 09:23 AM
I once disassembled a hatch. What I recall is there is a special tool needed for the spoiler to hatch fastener screws. It looks like an inverse flat tip screwdriver. I won't attempt to describe it further as most of you own 944's and can go outside and look at it if you are curious.
I would check to see if the screws were re-installed and are tight. It is also possible the fasteners embedded in the hatch foam have been ripped out.
When I tried to remove parts of the spoiler, I didn't have the proper tool, so I improvised. I managed to get some of the screws out but the next issues was the spoiler was stuck to the glass due to grime build up. I managed to remove the side parts of the spoiler, clean them up and reinstall them. I gave up on the main center part of the spoiler and left it as it was as I was afraid it would get destroyed.
Maybe others have some additional advice.
Old 12-29-2012, 10:01 AM
Motor Head
Sounds like possibly some hatch/spoiler separation issues. Here's a funny write up off of 924board by Rasta Monsta. Not sure if he posted it here as well or not but Google search brought it up on the 924 board. Click me! He shows the tool needed to remove the nuts from the bottom side of the spoiler and he did it similarly to how I did mine on my old 931 when I upgraded to a 944 spoiler. Just cut the center section out of an old flat blade screwdriver and it works great!
2013 Ford Focus SE - 5spd mtx, Spectre filter, Unleashed E85 Tune, much more to come. - DD
2011 Ford Flex - Catless Downpipes, lightweight Mustang Motorsport 20x8.5 wheels, 3 bar MAP, Unleashed 15 psi tune - SOLD
1986 944 Turbo - 100K mile cream puff - FOR SALE
Old 12-29-2012, 12:04 PM
