Rough revving
I got the "new" engine in and spent half the day driving the thing around. I've noticed that above 3500, mainly above 4,000, it revs kind of rough. I can feel the vibration in the stick, and it just sounds different. The balance belt is good, the oil pressure is good. I'm running dinosaur oil in this engine instead of mobil1 to stop the leaks that it will surely have. Any ideas on the rough revving? It pulls like a scalded cat, just doesn't feel quite as smooth. Maybe an exhaust leak?
Could the balance shaft sprocket things being on 180 degrees backwards do that?
mueller,
I read a lot of your previous posts, the car has had a lot of problems since the rebuilt Blazak engine. Recently the rod bearings: http://forums.pelicanparts.com/7010837-post1.html Usual rough or vibration occurs at 3300rpm~+- if the FW & PP are not balanced correctly. Could it be the Kevlar Clutch disc? http://forums.pelicanparts.com/6766320-post1.html But, did you ever find the oil leak? http://forums.pelicanparts.com/6773426-post2.html Have you contacted Blazak about the problem? http://forums.pelicanparts.com/6777422-post4.html He is right, the clutch may outlive the engine... It is difficult to work on the car while in school, good luck. J_AZ |
Turned out the balance sprockets weren't lined up.
I did run into a lot of issues. Clutch did outlive the engine, put it on my new engine. I have talked to Markus Blaszack a lot, he's been very helpful over the years with various questions, I still turn to him when something goes wrong on the car, whether it's with the engine or not. I'm gonna slowly rebuild that other one to be a 3.0L turbo. |
.......I was actually right? *mind implodes*
I almost might have to change my user title.
| All times are GMT -8. The time now is 06:00 AM. |
