What Air-fuel gauge do you have?
What air fuel gauge do you use?
Do any attach to an independently purchased oxygen sensor - i.e. the sensor is not built in? Is this technically dubious?
Old 01-09-2013, 11:31 AM
flash968's Avatar
the only accurate and useful gauges use a wide band O2 sensor, and not the narrow band like what is in the car already.
as a rule, an analog gauge is more accurate and easier to read than a digital one. the wider the sweep angle, the easier and more accurate the reading.
there are a number of good gauges out there, and you really have to decide what you want to see in your car.
once the car is properly tuned though, there really is no need for a gauge.
i recommend an LM-2. that allows you to log data and tune. then, when you're done, you don't have to worry about sensors dying or a place to put your gauge
Old 01-09-2013, 11:41 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Using the Innovate LC-1 with the XD-16 multi-function gauge and the DL-32 Datalogger. With the DL-32, there is no need to carry your laptop with you to datalog, records to an SD card. Great for recording data at the track or real world street data.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 01-09-2013, 01:47 PM
winter-hater club member
nynor's Avatar
i have the AEM wideband. it works great. i wouldn't put different chips in my car until i had the wideband to verify that the A/F ratio was good.
"COOL PRIUS!" - Nobody Ever
Old 01-09-2013, 06:22 PM
That Guy
Techno Duck's Avatar
Innovate LC1 with the XD-16.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-09-2013, 07:28 PM
