Two issues
First, I bled my clutch last weekend because the clutch is randomly sucking to the floor. After bleed, still same problem. Going to try to bleed it again, but if not better, that means the slave is bad, right?
Second, I've always had a "fuel smell" in my car, and I'm going to redo the fuel lines and what not to try to alleviate that. However, lately I've been smelling like the car is running really rich. What causes this, and how do I go about diagnosis/repair?
Thanks.
Guy
'87 944 (first porsche/project car)
Old 01-02-2013, 07:43 AM
How long did you bleed it for? Sometimes it takes a long time. How did you bleed it? Check for brake fluid squirting into the bell housing.
Old 01-02-2013, 07:48 AM
With a pressure bleeder. Old fluid was dirty. Bled it until saw nothing but clean new fluid that came out in a steady stream...and then a little bit longer.
Guy
Old 01-02-2013, 08:08 AM
If the master and slave are original I would start looking there.
86NA944
Old 01-02-2013, 08:50 AM
So, you'd recommend I replace both?
Guy
Old 01-02-2013, 09:13 AM
ernie9944's Avatar
If one need to be replace the general practice among 944s owner is that they replace both at the same time.But be aware that changing the master cylinder (carpet cylinder) is a PITA & require lot more work than the slave.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-02-2013, 10:06 AM
Sounds fun. Thanks, Ernie.
Guy
Old 01-02-2013, 10:09 AM
