cold start remains on...1983 944
Help, after start, when the engine warms up a bit it runs very rich, black smoke stumbling,etc.Changed coolant sensor, fuel pressure regulator,DME, DME relay and no luck. Above 3500 rpm runs OK, so I believe the No 1 injector is pumping too much fuel after cold tart? Thoughts?
Old 01-09-2013, 08:31 AM
AFM #725
Gawernator's Avatar
O2 sensor?
Old 01-09-2013, 08:54 AM
Don t think its O2 , tried bypassing it, and it is very very rich.
Old 01-09-2013, 10:13 AM
AKCJ's Avatar
Take a look at the barn door inside the AFM. Could be stuck? Also, I would suspect the AFM track - if it's worn out you can adjust it (do a search and check out the video on utube).
Also check the connector at the AFM, clean the contacts.
If it's running rich it's probably too much fuel but could also be lack of air - check the air filter.
Red 83 944
Old 01-09-2013, 10:33 AM
yes, im going to take the AFM apart, have a look.
Old 01-09-2013, 11:52 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
