schmedes1's Avatar
Rewinding Rear Hatch Cover is Pain
I have a 1989 944 with a solid rear seat back and hatch cover. Went through lots of pain to get the end units for the broken hatch cover connection ends (the ones that get old and brittle -- plus you have to go through the whole rewind procedure). Problem is that now that I have installed (aluminum rivet) the end units, the SPRING released and have no tension on the cover. Is there a slick way to retension the spring or do I need to remove the rivets and start all over again
1989 944 Turbo (100% stock and restored)
1996 Mustang Cobra - Track Ready via Griggs Racing
Old 01-28-2013, 11:03 AM
I believe you will need to start over again. Sorry.
Old 01-28-2013, 11:14 AM
How do you re-wind the spring???
Old 01-28-2013, 07:58 PM
You can make a tool for the spring by using a wooden dawl rod. Cut a groove in one end to slipover the bent spring end and turn.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 01-28-2013, 08:15 PM
Misunderstood User
Cheers,
Larry
Use a fork to wind up spring. Drill out the rivets and replace them will small button head screws
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 01-29-2013, 05:55 AM
I cut mine out. Really have no purpose for the cover, wouldn't wind up, so I took a knife and now it'll never be an issue again
Guy
'87 944 (first porsche/project car)
Old 01-29-2013, 08:59 AM
schmedes1's Avatar
Hi jcommin: Good idea about using the fork to rewind, but unless you had better luck than me, it was not feasible to use screws because the cover ends/assembly was designed to fit flush against the back of the seat... the screw heads throw off the fit and decided to just use the rivets.
Old 01-29-2013, 11:09 AM
schmedes1's Avatar
Hi gacook: not sure if you are saying you removed the cover completely, and what the heck did you need a knife for unless you just cut off the fabric all neanderthal style I am keeping my car 100% original and hope to show this year or next once I replace a couple of front end body panels.
Old 01-29-2013, 11:12 AM
schmedes1's Avatar
Cheers,
Larry
Appreciate you Larry!
Old 01-29-2013, 11:13 AM
Yup, I went neanderthal style on it. Plan on replacing it in the future with a working roller (maybe), or just completely deleting it once I recover the seats. My car's a "project," so there's much work to be done still. Carpet/seats will probably be the last leg of the journey.
Guy
Old 01-29-2013, 11:16 AM
Misunderstood User
I made my end caps out of metal and I either used flat head or button head cap metric screws. Car is covered up right now but If I get a chance I will post photos.
Jim
1983 944n/a
Old 01-29-2013, 11:24 AM
