How old are your sensors? Since they so commonly cause problems I would think it'd be a good idea to eliminate that as a cause.
Janet '83 944 |
Clark's garage has a test procedure for the throttle position switch. You said it is adjusted properly (clicks when the throttle is closed) but is it working?
The thing that's puzzling me is the engine will run with the DME coolant temperature sensor unplugged.The sensor tested fine, but for some reason it just won't run with it in place. Later today I plan to start the car, warm it up, then plug the sensor back in and see if that makes a difference. It's brand new, but I'll test it anyways. |
AFM #725
I would get another temp sensor then.
My solution to the problem of wanting to set mine on fire has been to yank the whole damn power plant out
Janet '83 944 |
The temperature sensor tested fine when I checked it at the DME connector/the sensor itself, so I don't think it's causing my problem.
I'd rather not pull the engine for this because I don't have the tools to do it. I'm a little short on cash at the moment, so I can't afford the equipment required. I've never pulled an engine before, so it would probably take me forever and I need a working car ASAP. |
Gaw, the bleed screw is a special bolt, it has a hole drilled thru to allow the air to escape without completely removing it.
Up to you, but you may want to order the correct one. I do realise this is your only car.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Janet '83 944 Last edited by Jferr006; 02-06-2013 at 09:06 AM.. |
Will do! |
Won't be part of it,until now all mine need is gas in it (well not exactly need to refresh the alternator later next month) but nothing that keep her from running.Lol just crossing my fingers here & touching wood that my luck don't run out .GL trying to solve your issues sometime problems like yours are SOB to put your fingers on & very frustating.
AFM #725
![]() I just discovered that my #2 spark plug hole is stripped. I'll have to pull the head and helicoil it. I hate this ****ing car beyond belief!!!! There's always one thing after another ![]() |
AFM #725
You can always part it out or sell it
I really don't want to part it out because I don't have the time to do it. If I sold it I'd get like $500 for it, so I'd be out like 4 grand. Having a working 944 would be a dream come true. In the month or so that I was actually able to drive it, it was fantastic and I'd like to experience that again.
If I find scored cylinder walls, then I'm not going to bother fixing the engine. I'll swap in a v8 or something |
AFM #725
You'd be happier with a 968 swap
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Probably, but 968 engines are kind of rare/expensive. I have my fingers crossed that I wont find any scored cylinder walls.
I removed my timing belt cover and the interior is coated in oil, so this gives me a good excuse to do the front engine seals/timing belt. Maybe I'll paint my cam tower while it's out too. I'd better start saving my pennies.... |
Quality
Did you have a spare DME (brain) to try? haven't read this thread. Just some random posts.
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress... ![]() |
Maybe I'm missing something, but why would you have scored walls? I've scored the walls on two different engines so I know how you feel. You replaced the sensor, but how is the wiring leading to it? Any damage to the wiring harness?
The wires behind the boot are fine. I'm not sure how they look inside the harness. The harness itself looks fine. It's still nice and flexible with no dry rotting or cracks. |
Thread Tools | |
Rate This Thread | |
