-   -   engine running rough (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/73307-engine-running-rough.html)
RJ Santangelo 07-02-2002 11:33 AM
Sunday i got into my 87 944S and the engine ran very rough ie. like only on one cylinder. after about 3 minutes it smoothed out and it was ok, once i gave it a little gas and the rpm's started to come down to idle it started to run rough again. I checked all the plugs and cap/ rotor all ok- timing also good. Needless to say i started the car again but all was ok 2 minutes later once again running rough. does anybody have any suggestions or has experienced this????????????
944jeff 07-02-2002 12:21 PM
First probable cause would be the DME (aka fuel pump) relay. This could be your trouble and it is considered a maintenance item to be replaced at some point. I had similiar symptoms.
RJ Santangelo 07-02-2002 03:44 PM
just had the DME relay replaced in December, but that doesn't mean it could of failed.
icat 07-02-2002 07:28 PM
Have you ever had the motor mounts replaced? The engine will run ruff at idle if the mounts are gone, and then smooth out once you build up speed. http://www.pelicanparts.com/support/smileys/men_ani.gif
RJ Santangelo 07-03-2002 06:52 AM
brand new mounts only 230 miles on them
