He means turn it up to like 1,000 :p
I checked the two grounds under drivers side dash. Both were tight with no corrosion. So that's one down on the tach.
I also checked the "y" tube mentioned a couple posts ago and it looked good and secured as well as everything around it. Will the method mentioned with a youtube link work the same on an NA as the turbo. The video had a turbo in it and I wasn't sure if the vacuum was similar or not. |
Did u check ur J boots from the Air filter to the AF. M meter? For cracks? Rubber drys with old cars
| All times are GMT -8. The time now is 05:50 PM. |
