oil cap vacuum
Is there supposed to be any vacuum on the oil cap while the engine is running. Currently my car is at :
950 RPM with the cap on 850 RPM with the cap off 900 RPM with the dipstick out. Is this normal or not?
Black 1984 944 2003 Land Rover Freelander SE3 Last edited by Ederd; 02-26-2013 at 07:59 PM.. |
AFM #725
Well the Oil fill is connected to the AOS which uses vacuum so I would say yes. I just replaced my Oil cap seal in my quest for fixing AOS issues and vacuum leaks
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
I was wondering bc on my other two vehicles there was no difference in idle when I took their oil caps off for a comparison. Different engines, 2.5 KV6 and a 5.2 V8, but I was seeing if the principles were the same. Learning 3 engines at once is a little confusing sometimes.
Black 1984 944 2003 Land Rover Freelander SE3 |
porscha
U can Aleays spray intake cleaner around the places I think there is a vacuum leak to confirme it!
Some engines do, some engines don't. As for the 944, I'm not sure. Just for reference, a BMW M20 does pull vacuum from the valve cover, and runs like total ass with the oil cap off. I found that out the hard way last time I changed my oil in a hurry!
Parting '84 944 with 103k. Pics here: http://smg.beta.photobucket.com/user/cheezus/library/944?fromLegacy=true |
AFM #725
Again I will say yes. The oil fill is part of the air oil separator. Whatever goes in there will go to the intake. And it works off vacuum. It only makes sense you would be leaking vacuum with the cap off.
