clutch replacement
There are many benefits to pulling the engine out of your 944. Am I the only one who would pull my engine to change my clutch.
I've done it before
Just curious???
1988 944 turbo
Old 02-26-2013, 11:35 AM
Kevin.'s Avatar
When the time comes for my clutch replacement, I will do the same.
Old 02-26-2013, 04:28 PM
AFM #725
Gawernator's Avatar
You're just adding to my nightmares
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 02-26-2013, 04:40 PM
Custom User Title
mikepellegrini's Avatar
Six of one, half a dozen of another.
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 02-26-2013, 06:45 PM
9FF 9FF is offline
9FF's Avatar
If you can drop the engine and torque tube together, dismantle and replace the clutch on the ground and lift it all up as one unit again, that would be much easier. Is that even possible?
Old 02-26-2013, 06:52 PM
My opinion is if you have to do anything to the motor like belts, seals, mounts, ect then pull it. If not then just drop the transaxle.
Dropping the transaxle is less tool intensive and you won't have to get an alignment (if you drop the engine rather than pull it).
I think when replacing the clutch you should inspect and regrease the cv joints. Also, it would be a good idea to replace the oil in the gearbox and maybe replace a couple of it's seals. You could even take a look at the ring and pinion if so inclined.
Old 02-26-2013, 07:28 PM
White and Nerdy
Tervuren's Avatar
For a clutch only job, I'd drop the the transaxel. I've done it several times, its not that hard.
If I was rebuilding the whole dang engine, then yeah, take it out.
If you find you have noisy torque tube bearings, you'll be dropping out the tranny anyway....
Old 02-27-2013, 10:43 AM
Frankly my dear....
rhett's Avatar
My first 944 clutch job was a gearbox out, torque tube back and lay on your back and work above your head nightmare. There is so little room you can end up getting hurt (well I did!). Got it done though and it's quite straightforward in general. My second was an engine out job. The engine was being swapped so doing the clutch was a breeze with the block just sitting there. To be honest, if I had to do another I would probably pull the engine and do a lot of other service 'stuff' to it as well. I found dropping the engine easier than trying to lift it out - just my personal experience.
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 03-03-2013, 12:23 PM
Kevin.'s Avatar
The "lay on your back working above your head nightmare" is what I will want to avoid.
That would be the only reason I would need to pull the engine.
Old 03-04-2013, 05:25 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
Believe me , dropping the engine still involves plenty of laying on your back work(remove exhaust, starter,clutch slave,steering, cross member,radiator, and fiddly little job disconnecting the torque tube) but at least once the engine is out you can change clutch, pilot bearing and RMS in a more comfortable fashion. You need to lift the front bodywork so that the bottom of the valance is at least 25.5" off the ground. If you tdrop the engine whilst still mounted to the cross member it will save having to undo the engine mountings which have some awkward to get at bolts.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 03-05-2013, 03:13 AM
Rod Schneider's Avatar
I find it far easier to remove the transaxle for a clutch job. Less than two hours to get the clutch out. Of course, it may help that I have a two post lift and can do the entire job standing up under the car.............
Rod Schneider
Ball Ground, GA
88 928S4, 87 Corvette,
88 Fiero GT, 16 Mustang EcoBoost
Old 03-05-2013, 06:21 AM
Either way you're going into your car pretty deep. With your engine out you can replace so many things that you'll be happy you did.
Old 03-05-2013, 03:30 PM
porschetub's Avatar
X2,drop the box, clean it, repack cv's etc,don't drop the motor out from the bottom if you do the motor out job,out the tops easy.
With g/box and t/tube out of the way you can get to the bellhousing bolts by tilting the motor and on reassembly you can retorque the clutch bolts thru the starter motor hole.
Buy or make a flywheel lock, theres other stuff I may missed cause its been a while,good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 03-06-2013, 12:36 AM
