List - Questions - work done to my 944 ;)
Well, I made an actual list of things I do need to start working on the car. For my next order. Feel free to help me get the stuff if you'd like. Just postin up my next order to do to the car.
All new Spark Plugs Plug wires Passenger side Window Switch Passenger Door Handle is very stiff might need a new one? Suggestions on that one? Rear Hatch Frame?? if possible to find lol Hood Struts and Hood Arms *Arms that actually hold the hood on* Driver Side Weather Stripping Rear Hatch Struts and latches Hood Upper Latch and Lower? Starter/Starter rebuild kit? Suggested Fuel Injectors Suggested Fuel Rail? Any Suggested hoses/lines due to original everything. Rear Wheel Outer Bearings? Front Wheel Bearings? Heater doesn't work electrically, Ground bad? or is it a resistor? or? Fan works good. Well the things I do have questions about now. Steering coupling loose? Seat Bolt down Nuts are just turning in place *Just Weld them in place?* Rear Seat removal for flat carpeting and some customization for a flat trunk all the way to my front seats. I could mount my sub/amp inside it and stuff it nice and well for quality sound. Would I really need the lower latch for the hood if its a ***** to open? Its not the original Hood or Nose Panel. Would like to Make that work properly. 3 years ago it was wrecked and it dipped under the car infront. Nosepanel/Hood was destroyed. As well as the Popup lights. All works, Hood latches might be bent? Would you think thats possible? Hood was Wrinkled bad and nose panel was backwards. Lol Bumper was good, ;) Work done to it Replace front engine seals/Including cam seal/balance shaft seals and front crank shaft seal. Replace timing belt and balance shaft belt. Replace H20 Pump and tstat. Rear Output shaft seal, driver side seat, AC converted over to new style, Distributor Cap and rotor, Flowmaster Muffler, Rear Axle Shaft Boots/Bearings re-packed on both sides. Driver Side Seat reupholstered and re-cushioned. Clutch master cylinder Clutch slave cylinder Clutch Kit clutch lever bearing Clutch lever shaft Pilot bearing release bearing guide Crank seal Shift Lever DME Relay Air mass meter ex. Fuel Filter Fuel Sending Unit Radiator Aux Fan Switch tstat circlip tstat shim orings |
Fuel injectors, send to Witchhunter or get rebuilt ones, BOSCH. Why do you need a fuel rail, unless your is cracked/leaking? You can probably bring your door handle back to life by spraying white lithium grease inside the door handle, worked wonders for me and helped a few others I told. Your hood doesn't attach? Try calling Parts Heaven or finding a parts car. Do all vacuum lines and all fuel hose. check fuel rail jumper hose. Why do you need new wheel bearings? Inspect, repack and tighten
Passenger window switch - swap with a drivers side switch to verify that the switch is bad.
Spray bad switch with contact cleaner are push on it a bunch of times. Most likely it will start working again. |
New injectors 47$
Witch hunter 28 $+shipping per injector. Door handle I was thinking that. Hood doesn't.latch correctly. Window button I've done that. Its the switch. Rail replacement. Might have little rust marks. Ill pull off and sand down. |
How the **** did your fuel rail rust? It's cadmium plated. Take the switch apart and clean the contacts with an eraser inside. Almost guarantee you it will work. Lol I fixed two switches that were "dead"
I've cleaned the contacts....But i'll try. Its weird cause one side will work when the other is unplugged.? Wiring issue? Lol I plan on getting the wiring re-done. Depends though. New Fuse Box/etc. |
You took it completely apart and cleaned all surfaces heavily with an eraser?
cleaned every Connection to a good one, even use my extension to clean where it plugs into. Its as if... I unplug driver side then passenger side works. But when I plug in driver side. Passenger stops working. |
| All times are GMT -8. The time now is 08:47 AM. |
