Driving on borrowed time.....looking for a mechanic.
Alright, So I bought this '86 951 a couple of years ago from an individual who said he bought the car at auction. He said he was the second owner. I bought it with no prior records. I know, I know, I committed one of the deadly sins of car buying. But after looking the car over carefully and driving it I determined it had been pretty well taken car of. The interior was perfect. No dash cracks; no wear at all on the sport seat bolster, etc. The exterior appeared to be all original with original paint and no accidents. The mechanicals all appear okay. The car appears totally stock except the K&N filter and a period correct Alpine cassette stereo.
I have since replaced the tires, a rear tail light, a front fog light, all the fluids and a few other minor odds and ends.
The car had about 59k miles when I bought it. I have since driven about 4k miles in the last two years.
The only mechanical failure has been a recent failure of the clutch slave cylinder. I had a local shop replace the master and slave cylinder and the line between.
Now I need to replace the timing belt/water pump, etc. I'm looking for a mechanic in Atlanta, Chattanooga, Knoxville or Asheville areas. I live in Murphy, NC which is about 1.5 hours from any of these areas. I trust my local guy to do most basic repair work but would like to have someone who has done 951 tb/wp replacements before.
I have received a reasonable estimate from Jordan at Technica Motorsports in Atlanta.
I have been following you guys on the 944 forums for the last couple of years and really value your opinions. Any recommendations would be appreciated.
Thanks,
Tom
Old 04-17-2013, 10:59 AM
Dave Colangelo's Avatar
I dont live in the area but just a general word of wisdom,
In this case go to a Porsche specific shop. As you have already mentioned you would like some one with experience doing this sort of thing and that is the right track, but I would only take it to some one with a bunch of 944/951's in the lot. The WP and TB take a bunch of special tools to change (although it could be done with out them) I would only go to a shop that has these tools and knows how to use them.
I dont know the 951 specifics but if the engine is as similar to the NA as I think it was not until 87 that the automatic tensioners were added so the belt may have to be tightened after it is installed and run a bit.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 04-17-2013, 11:29 AM
Try the Mechanics files over at cartalk.com and search by city and by Porsche. Following that - Call and interview them asking specifically if they've had experience doing belt replacement on the 944/951/968 - if not, look elsewhere. Ask if they use the Porsche 9201 tool to set the belt tension. If they don't - look elsewhere. You're looking at a front end reseal, coolant pump, belts, and rollers. Cost to you should be in the vicinity of $1,000.
Note that you'll need to go back in 1,500 miles to have the tension checked again.
The "automatic" tensioner came out for the '87 model year. I'm working on one now. Your car will have the earlier style eccentric-roller type tensioner.
'73 911T (Since '83 - PCA since '84), '10 C2S, '85 944 (Gifted), '83 944 (Sold);
BMWs: '00 328i ZSP, '03 525i M-Sport, '01 325i (Totaled), '96 328i (Sold), '97 328i and '07 328i (Daughter's)
Old 04-18-2013, 09:32 AM
My 2 cents.
Without records, you should replace the Timing / Balance Belt, Water Pump, Front of Engine Seals, and Rollers. Get your estimates for all of these and make sure you know what kind of Water Pump is being installed (new or rebuilt and if rebuilt by who). There is a wide range of prices for water pumps. Off the top of my head, I bet you get estimates somewhere between $1,200 and $1,500 if not more. And don't forget you will need to retension the belts after the first 30 days.
If you have mechanical ability and the support of this forum, you can most likely source the parts and special tools (except 9201 tool to measure tension on belts) for under $800. First time I did mine I was scared to start it, but the job went perfect. My mechanical ability before I got the Porsche was limited to oil changes and fixing tires. I have the 86 951 also.
Good luck whichever way you go.
Old 04-18-2013, 09:49 AM
Ornery Bastard
Even with the "automatic" tensioner on the later 944s, the tension should be re-checked at 1,000 and 15,000 miles. Unlike the 968, which constantly maintains tension, the "automatic" tensioner on the 944 is a spring-loaded unit that is used to set the tension without the engine running and then locked down. It does not continuously adjust the belt tension as the engine runs; it just reduces the dependance on the P9201 tool for setting the static tension.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 04-18-2013, 09:59 AM
Andrew Gawers' Dad
CHICKS's Avatar
Tom, why don't you do this work yourself? There's a ton of info out there, and we're all here for your questions. It's really not that hard to do at all. You'll save a lot of money, even if buy all the special tools.
Old 04-18-2013, 06:36 PM
AFM #725
Gawernator's Avatar
I agree ^
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 04-18-2013, 11:43 PM
Mein Gott!
Panzer909's Avatar
A-fricken greed! It sounds like there's a lot of going back & forth to a shop even if/when you do find one and the labor bill for the job these days is mucho expensivo to say the least. When I first tackled this job myself, I went all out and did the full belts/rollers/WP/fluids/front seals and all kinds of little nik-naks while it was all apart. And you know what? it was NOT a difficult undertaking. You just have to spend time taking everything apart.
You'll learn a lot about the car in the process and dare say that it will be a lot of fun. There will be many "oh this is how it works!" moments. This board will help you through any roadblock you might encounter along the way. Then you can write yourself a check for $1000.
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 04-20-2013, 12:21 PM
Phantoms's Avatar
If you are still looking for shops my recommendation would be European Motor Car of Atlanta. They have 4 locations, I usually go to the Alpharetta/Windward one. They always do quality work but are on the pricier side.
1990 S2 Coupe
Old 04-20-2013, 03:16 PM
Nearly identical story!
86 na, I've put about 10k on mine since I got it 3 years ago, really want to do the timing belt, water pump and all the other stuff while i'm in there.
I can wrench a little, done about 4 or 5 tb's various cars, but I've seen that on this I have to have a special porsche tool, than I've heard there is a work around?
Anyone point me to a link?
Old 04-21-2013, 09:08 AM
AFM #725
Gawernator's Avatar
Arnnworx makes some tensioner tools that are much less expensive
Old 04-21-2013, 12:14 PM
Mein Gott!
Panzer909's Avatar
+1 with Arnnworx. I've had great luck with all of that guy's tools. His special wrenches to hold the rollers are fantastic BTW
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 04-21-2013, 05:25 PM
Andrew Gawers' Dad
CHICKS's Avatar
+2 on Arnnworx tools, they are made really well, Bruce is a great guy, and you're helping a fellow 944 owner.
Old 04-21-2013, 06:12 PM
